Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 10-30-2005, 01:13 PM   #1
amolai
Member#: 98021
2001 Mazda Miata
Default Why is my clutch wierd?
Hey guys! i had a quick question. Me and my cousin both bought 05 Blue WRX with premium package, he bought his 6 months ago and i bought mine 1 month ago, my question is : i drove his car last night and he drove mine, to my surprise his clutch was alot stiffer and it felt alot better than mine, mine feels alittle spongy and his is really stiff and nice. im not sure whats up with them but if anyone know anything please help!
amolai is offline   Reply With Quote
Old 10-30-2005, 01:22 PM   #2
shikataganai
Member#: 92634
'07 Land Cruiser
'12 RAV4 EV
perhaps you need yours bled
shikataganai is offline   Reply With Quote
Old 10-30-2005, 01:23 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Your clutch may have some air in the hydraulic lines and need to be bled. How does the amount of free play compare between the two, does yours have more free play than his?
If you have reason to suspect that there is air in the system have your dealer check it and bleed it if necessary.
Old 10-30-2005, 01:23 PM   #4
amolai
Member#: 98021
2001 Mazda Miata
would bleeding it make it more race car like?? (stiffer/tighter) Thanks
Old 10-30-2005, 01:25 PM   #5
amolai
Member#: 98021
2001 Mazda Miata
mine has alot of play, on his you barely have to push the clutch in and its all the way down, mine it seems like its about 4 times the length (pedal going down). im not sure if thats what you mean, hope that helps
Old 10-30-2005, 01:34 PM   #6
amolai
Member#: 98021
2001 Mazda Miata
Also his clutch like responds better and it makes shifting alot smoother and easier, his pedal pushes back on you foot when you let it out, mine is really soft
Old 10-30-2005, 01:38 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Your description does sound like it has air in it, go to your dealer and have them bleed it.
Old 10-30-2005, 01:41 PM   #8
amolai
Member#: 98021
2001 Mazda Miata
Alright, Thanks alot Mulder, ill go and have it checked as soon as i can, would this air cause any damage to my clutch? i hope its just air though Thanks alot, ill post what the dealer tells me tomorrow. Thanks again
Old 10-30-2005, 01:41 PM   #9
Idahoser
Member#: 78147
93 impreza 4dr
280.000 and runs 100+
Exclamation
Also, the type of fluid you use makes a difference. DOT 5 is silicone based and is the best IMO.
Idahoser is offline   Reply With Quote
Old 10-30-2005, 01:43 PM   #10
amolai
Member#: 98021
2001 Mazda Miata
do they change the fluid during oil changes or something? how often do you have to change the fluid?
Old 10-30-2005, 01:46 PM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It won't cause damage to the clutch, but it can increase wear in the transmission, particularly the synchros, due to the clutch not disengaging sufficiently when you shift.
To respond to the fluid comment, you don't want DOT-5 anywhere near your car. It will not mix with the conventional brake fluid that is already in the brake and clutch systems, and is also NOT compatible with ABS braking systems.
DOT 5.1, that's a different story. That you can use.
For the clutch plain ol' DOT 3 or 4 is just fine, and of course it should be changed regularly along with the brake fluid.
why oh why is my neighbor's wife... INFIDEL Off-Topic 160 05-13-2008 09:37 PM
Why is my clutch so heavy? JonM in MN Newbies & FAQs 6 12-14-2006 11:10 AM
why is my clutch pedal so heavy??? subaru7717 Legacy Forum 13 11-09-2006 01:19 PM
why is my bov louder when my car is cold sam caldwell Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-28-2005 09:02 PM
Why is my car idling wierd? jasona Normally Aspirated Powertrain 13 02-22-2004 09:31 PM
