10-30-2005, 01:14 PM | #1 |
Member#: 76649
Vehicle:08 Z06 Victory Yellow |
Recommended UTEC Knock Threshold settings for STi?
Are these the recommended knock threshold settings - I saw these on my UTEC (just a heads up: I'm not the tuner) and also on TurboXS websites.
Engine Mods: GT30R, UR up/dp. tial 44mm EWG, Halman Pro MBC set to 20 psi, Spearco TMIC, PE 850cc, Perrin rails, UR intake, Koyo rad, Greddy Type-S BOV recirc, lots of IC spray (not injection), UTEC w/ Ecutek Knock Threshold settings set to: idle to 2K: 105 2K to 3K: 100 3K to 4K: 92 4K to 5K: 75 5K to 6K: 72 6K to 7K: 65 7K to 8K: 63 8K+: 60 This is where my setup is different: Knock count threshold set to 3 And my setup goes back to their params: Knock retard step set to 1 knock max retard set to 10 knock retard duration 100 cycles Also, I noticed that the TPS doesn't read zero at idle - or even with the car not running - it reads 6. I have to go back and verify it reads 100 at WOT. I assume I do that with the car off and use the dashboard.
10-31-2005, 12:37 PM | #2 |
Member#: 84313
NWIC
Vehicle:04 Aspen STi |
dont touch them unless you have forged pistons
10-31-2005, 10:03 PM | #3 |
Member#: 76649
Thanks, yeah I know not to lower the numbers - my question is whether they should be higher and are these the recommended settings from TurboXS?
And if not (for the Sti) then what are they? |
10-31-2005, 10:15 PM | #4 |
Member#: 21980
NESIC
Vehicle:2002 PSM WRX (Sold) 2017 BMW X5 |
Those are the default settings from TurboXS for the STi. I'd leave them there as the default settings seem to work ok. You could increase them a little bit but there is no reason to do so unless you have a way to verify that any knock you get isn't just engine noise.
properly set utec knock thresholds | ride5000 | UTEC | 9 | 08-25-2006 01:14 PM |
Tinkering with UTEC knock thresholds... | cdvma | UTEC | 3 | 03-12-2006 06:14 PM |
knock threshold setting on utec | RACER1269 | Engine Management & Tuning | 6 | 10-30-2005 12:06 AM |
UTEC Knock threshold safe setting values help | AXA | Engine Management & Tuning | 12 | 10-07-2005 10:35 AM |
UTEC Knock Thresholds | D_REX | Engine Management & Tuning | 2 | 09-22-2003 06:22 PM |
