Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 05-11-2001, 06:09 AM   #1
teen's dad
Member#: 5409
Post oil cooler worth it?
Have an Impreza 2.5L RS my01 and am considering adding an oil cooler. Would the cooler lower the oil pressure? Is it worth it? Would also like an oil pressure gauge, but don't want the idiot light on constantly if I bypass the original sensor. Thanks.
teen's dad is offline   Reply With Quote
Old 05-11-2001, 06:28 AM   #2
jlyttle
Member#: 2815
2004 Forester XT 5sp
Post
Not unless the car is run in competitive events more demanding than auto-x that really get engine temps up, or if you tow with it or something. In other words, if you treat it like a normal car, you probably don't need an oil cooler. It definitely won't hurt! But save the cash.
jlyttle is offline   Reply With Quote
Old 05-11-2001, 06:44 AM   #3
outback motorsports
Member#: 4084
Post
you can drill and tap the plug with the allen head on it next to the bell housing rubber cap .put a 1-8 pipe on it and you can use it for turbo feed also.see ya steve
outback motorsports is offline   Reply With Quote
Old 05-11-2001, 06:48 AM   #4
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Post
I believe it will lower oil temp not pressure. Here is info on the OEM oil cooler I have:
http://www.azscooby.com/mods/AZScoob.../oilcooler.php
Peaty is offline   Reply With Quote
Old 05-11-2001, 06:53 AM   #5
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
Yeah, it will lower the oil temp, but not the pressure. And, the idiot light will not come on unless the oil is at extremely low pressure (5psi or less). It's been said that by the time the oil warning light come on, your engine is half gone.
As for do you really need it? Not unless your driving is very hard (i.e. a lot of racing and rallying). Oil cooler is not on my "I must get it" list.
tmat3 is offline   Reply With Quote
Old 05-11-2001, 07:10 AM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
if you car is an AT and you are racing it in any way... i'd recommend it... that and a tranny cooler...
if a 5sp... well it cant hurt, but you dont really need it...
j. www.subiegal.com
Old 05-11-2001, 07:37 AM   #7
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Post
From my experience (turbocharged 2.5L), the oil cooler is not really needed. I've done track days and haven't seen my oil temp above 220F (max).
Steve
http://www.forcefed4.com/
[This message has been edited by SteveS (edited May 11, 2001).]
SteveS is offline   Reply With Quote
Old 05-11-2001, 08:01 AM   #8
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Post
I put one in my car when I went turbo mainly because the OEM oil cooler was really cheap through my dealership and I figured it couldn't hurt. One advantage that no one mentioned, is that with the OEM coolent cooled oil cooler, the coolent warms up quicker and then helps the oil warm up quicker and then at one point reverse oil kept cooler.
Joshua
Subaru Salesman
yebokmj is offline   Reply With Quote
18x8 worth it here? AM5562 Tire & Wheel 0 06-01-2010 10:54 AM
Royal purple engine oil is it worth it? wrxkid157 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 03-03-2009 08:54 PM
Oil Cooler. Worth it or Not? woodenchopstix Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 11-16-2007 05:26 PM
Starion Oil Cooler, will it work? Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-05-2002 07:24 PM
Is the Subaru oil cooler worth it? jay25RS Normally Aspirated Powertrain 3 11-18-2001 04:30 PM
