10-31-2005, 01:19 AM | #1 |
Member#: 82612
Vehicle:2015 WRX STI Ice Silver Metallic |
Stalling at deceleration w/ standalone HELP
First, here's my setup:
VF39 turbo Link44s WRX standalone stock modded injectors 3in tbe stock intake, IC, etc Ok, everytime I decelerate the rpms will drop down to around 250 then kick back up. The faster I decelerate the more the car will want to die. It has never died, but once. I cannot seem to figure this out. I was wondering if it had something to do with my Clamp setting, which is set to 49kpa. If anyone wants my map I can send it to them to look at it. Everything else though is great! Thanks - Kyle.
10-31-2005, 02:00 AM | #2 |
Member#: 9861
RMIC
Vehicle:1999 2.35 RS-T w/NOS Hybrid Rally Blue Pearl |
Did you properly set the clamp setting? Basically you floor it and snap the throttle closed and look for the lowest map value that car hits, add a couple to that and that should be your clamp value.
10-31-2005, 09:53 AM | #3 |
Member#: 82612
Thats for overrun vacuum.
10-31-2005, 11:42 PM | #4 |
Member#: 82612
Someone has got to have some ideas here, HELP PEOPLE!
10-31-2005, 11:47 PM | #5 |
Member#: 88905
did you check for vacuum/boost leaks first? i have a utec in my car so i don't really know about your system, but from the sounds of it, it sounds like a leak. I had those exact symtoms and thats what it turned out to be. just a thought
11-01-2005, 08:47 AM | #6 |
Member#: 82612
Did not think vacuum leaks affected a MAP-based system. UTEC is MAF. But thanks for the reply.
11-01-2005, 11:06 AM | #7 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
no real ideas ...
is there a decel setting in the link do you have the newer firmware? |
11-01-2005, 11:50 AM | #8 |
Member#: 21980
NESIC
Vehicle:2002 PSM WRX (Sold) 2017 BMW X5 |
On my car (not using a Link) I've found that it coughs like that when the fueling isn't right on. Too rich or too lean and it can have a hard time keeping up a low RPM.
11-01-2005, 12:31 PM | #9 |
Moderator Member#: 922
Vehicle:16 WRX (white) 04 FXT (red) |
Sounds like your IAC isn't opening enough to catch the RPM drop fast enough.
11-01-2005, 01:40 PM | #10 |
Member#: 82612
I highly doubt it's the IAC..it's a problem of the standalone trust me because it's done this ever since I installed it. Also, it only does this once the car is warmed up fully. When cold-started the RPM's don't dip at all.
11-01-2005, 02:11 PM | #11 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
I know absolutely nothing about the Link.
However, with the Hydra Nemesis, there are several things that cause this: - Poor fuel tuning at low RPM sites under vacuum - "Max Vacuum" setting under the idle speed control settings. One sets this to 50-80mmHg more (larger vac number) than the typical vacuum while idling - "Moving Steps Up" setting under the idle speed control settings. This is a percentage to increase idle speed while the car is still in motion. Find something similar in your standalone. |
11-02-2005, 12:15 PM | #12 |
Member#: 82612
I found the problem! Turned out that my Hot Idle Duty Cycle was too low. Had it set to 32% and bumped it up to 36% and no more rpm dips in decel anymore! Thanks for the replies guys. - Kyle
11-02-2005, 01:06 PM | #13 | |
Tial EWG open at deceleration | WRX Loki | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 02-07-2010 01:20 AM |
wrx stalls at full throttle at high rpms | bluesubaru | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 16 | 03-23-2005 05:50 PM |
Help! Sti Stalling at low RPM (sorry, long) | BlackWRX | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 36 | 11-23-2004 07:40 PM |
RS-T Stalls After Deceleration | fukamoto | Normally Aspirated with bolt-on Forced Induction Powertrain | 10 | 11-23-2004 10:32 AM |
Stalled at idle... | RallyImprezive | Normally Aspirated Powertrain | 3 | 04-10-2001 01:30 PM |
