10-31-2005, 11:51 AM | #1 |
Member#: 57918
rough idle
ok so i just put in my reflashed ecu and started up my car. now it ildes really rough at times it will idle good. you can see vacuum is where it is supposed to be, around 15hg-17hg, but at other times vacuum will drop to like 9hg or 11hg around there. what could be the problem. could it be that when they reflashed it they set the timing incorrect or what? please help
other mods: vf22, walbro fuel pump, borla headers, helix up and down pipe, blitz cbe, hks bov, modded injectors, aem shortram intake what could be the problem?
11-01-2005, 11:48 AM | #2 |
Member#: 57918
what could be the problem? help guys
11-01-2005, 01:36 PM | #3 |
Member#: 27108
Vehicle:2004 STi 2004 A4 |
Do you have some way to check your fuel trims?
Rough idle, intermitent and rough cold starts... | carter_wrx | Pre-2002 Factory Turbo Powertrain | 26 | 10-28-2009 01:03 PM |
How Rough is a Rough Idle | Go350zGo | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 11 | 10-22-2009 11:28 PM |
rough idle, misfire, CEL funky high idle | carter_wrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 10-04-2009 02:44 PM |
very rough idle lean afr's at idle | TDagen | Open Source Reflashes | 8 | 07-07-2008 04:28 PM |
High Idle, Rough Idle? | Brettweiser | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 3 | 04-09-2007 11:10 PM |
