Old 10-31-2005, 07:00 PM   #1
Lavery
Member#: 77896
98 impreza 2.5rs
Default some help please idle issues(I've searched, trust me)
For the past couple weeks, I've been throwing p1507, idle speed control. I've been skimming by, not doing anything about it. The last time, I threw p0122 (TPS low-input) as well. I decided to try and clean the IAC as intructed by people on here and past threads. The problem is that the pictures/instructions were for new age engines...not my 98 rs.
So, I took off what I think is the TPS, inspect, don't really know what I'm doing, and put it back on. At the same time I took off what could be the IAC (however, it was just the top part, not the part that actually has air flowing through) Nothing out of the ordinary. I screwed both pieces back into place, reconnected all the wires, etc. Now, when I start up, I have an extremely erratic idle, and it never calms down, just keeps revving and sounding horrible.
Does anyone have suggestions of what may be causing it? Idle was fine before I started messing around with it. Also, can anyone show me exactly where the IAC and TPS pieces are on my engine?
Sorry for the long post. Thanks, LUKE
Lavery is offline   Reply With Quote
Old 11-01-2005, 01:07 AM   #2
Lavery
Member#: 77896
98 impreza 2.5rs
common, i know somebody can help me out
Old 11-02-2005, 01:36 AM   #3
Lavery
Member#: 77896
98 impreza 2.5rs
just downloaded service manual...I definately did not do anything wrong, so I don't understand what is causing the problem now.
Nobody has any suggestions...
Old 11-10-2005, 04:03 AM   #4
gpatmac
Member#: 18446
2002 WRX wagon
psm
I'm researching alongside of you. Mines a WRX, though, but what I've done so far is looked for leaks in the intake tract, I put together a DIY tool to fill up my intake tract with air to see if I can hear or see leaks (with some soapy water) [do a search for Kingtut on here], properly adjusted throttle cable (I had it misadjusted), ordered gasket for the IACV so I can clean it....still searching.
gpatmac is offline   Reply With Quote
Old 11-10-2005, 12:07 PM   #5
Rockstar25
Member#: 91833
98 black RS-Sold
Indy Forum's Kid
i have a ****ty idle aswell and have been told to clean the IACV but i couldnt find the damn thing on the 98. i did find it but it is near impossible to get off the engine. it is where the large hose on the intake conects from the airbox to the engine right below the PCV valve there will be a white thing with wires coming out. it is the Idle air control selunoid
Rockstar25 is offline   Reply With Quote
Old 11-11-2005, 11:54 AM   #6
4wdrift
Member#: 1403
99 RBP GC8 Impreza
Lavery,
Reset your ECU
4wdrift is offline   Reply With Quote
Old 11-11-2005, 12:37 PM   #7
drewdogg
Member#: 90003
2005 STi
If your idle is kinda bouncing, it sounds to me like the TPS is bad, and/or check for vacuum leaks. If the idle spikes then dies or hardly goes up at all, it seems to be the IAC. These things ive had problems with my engine swap, so maybe they'll direct you in a general direction.
drewdogg is online now   Reply With Quote
Old 11-11-2005, 10:19 PM   #8
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
After I installed the cruise control cable thingy, steering controller and the on/off switch, drove it around a bit then as I gased it this once, you know how you'd gas it a bit more and it'll knock once before the engine revving up, well after this I came to a stop sign and the engine almost died. It's threw the IAC code.
I dunno if the cruise control without the Cruise Control UNIT caused it or that it just happend...... I put on a '99 RS IAC thingy and pluged it with my harness, the engine would stay at 1900rpms all the time and sometimes at 1400rpms. At times it'd go up to 4k rpms! I switched back to the '99 L one. I'm thinking of just buying a new one if it doesn't work after I reset the ECU; overnight negative terminal from battery off.
FuJi K is online now   Reply With Quote
Old 11-13-2005, 11:31 AM   #9
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
UPDATE: It seems to be holding well now. I did unplug one or two of the ECU plugs with the battery terminal still connected. So maybe that might have caused it to do this....but it's doing fine now. weird....
Old 11-13-2005, 07:03 PM   #10
Lavery
Member#: 77896
98 impreza 2.5rs
haha...yes i reset the ecu and all that when i cleaned the IAC. Turns out my intake gasket was blown, which is pretty rare i think. It probly stemmed from when i ran out of gas. I got lots of backfires, etc. when that happened. CEL right after that.
thanks anyway guys
Old 11-13-2005, 07:28 PM   #11
gpatmac
Member#: 18446
2002 WRX wagon
psm
How'd you find out?
Old 11-14-2005, 10:26 AM   #12
Lavery
Member#: 77896
98 impreza 2.5rs
I finally broke down and took it to the dealer...how they diagnosed it, i have no idea.
Need some help please cel plus more!!!! thrasher679 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-04-2010 10:21 AM
NEED Some Help Please!!! From A Pro Please!!! kamyar12 General Community 9 05-05-2010 05:28 AM
Wife needs some Help. please spend some time. BREWPUBEAVER North West Impreza Club Forum -- NWIC 35 03-26-2009 04:53 PM
REALLY NEED SOME HELP---weird idling wrx182 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 10-22-2001 11:30 PM
I need some help PLEASE!!! Syms General Forum Archive 1 07-11-2000 08:54 AM
