Old 10-31-2005, 08:03 PM   #1
realwomble
Member#: 49305
2002 Stg.2 WRX Wagon
Default Clutch slip question
A friend has an 03 WRX MT with 39k miles on it.
His clutch has recently started slipping badly i.e. it's hard to pass 60mph, slips on hills, etc.
No high RPM launches, and he is the only driver of the car.
Is there any possible problem that could cause this other than simple wear?
(i.e. some problem which might be covered under the powertrain warranty (which lists the flywheel)) ?
Is this typical clutch lifetime?
Thanks.
realwomble is offline   Reply With Quote
Old 10-31-2005, 09:18 PM   #2
zaarin
Member#: 95404
2002 WRX Wagon
What color is bird crap?
I don't know what the problem could be, but that is definitely not the typical lifetime of a clutch so I would assume that it should be covered by warranty because that's not normal wear-and-tear. My clutch is 60k miles old and still grabs almost like new. I have an 02, so almost the same car.
zaarin is offline   Reply With Quote
Old 10-31-2005, 09:23 PM   #3
realwomble
Member#: 49305
Unfortunately I think only the flywheel is covered past 36k...
...hence my asking if there are other likely problems with same symptoms that make it worth taking in for a warranty claim - rather than taking it in and having the dealer open it up and then have to pay for their time when it's not covered (as a i'm pretty sure wear and tear isn't past 36k).
Old 10-31-2005, 10:56 PM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
How much experience does your friend have at driving stick? If you take it in for clutch slip they are probably going to be very uptight right away. They will probably want to charge you for dropping the trans and then go from there.
If they find blueing or fissures on the p/p or flywheel they probably wont cover anything=friend pays for all.
IF they find that the flywheel and pp look ok but the disc is gone then maybe they'll cover it all.
I guess bottom line is your friend should probably budget for at least 300$ which is about how much he'll pay to have it looked at.
Tim Sanderson is offline   Reply With Quote
Old 10-31-2005, 11:03 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Clutch wear is only covered under the 3/36 warranty, and then only when no damage from excess slippage is present as described above.
Old 10-31-2005, 11:40 PM   #6
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
clutch life is a huge function of how you drive - if you ride the clutch frequently, then it will wear out really quickly.
DrD is online now   Reply With Quote
03 N/A Clutch Slipping -> Replacement Questions stoney98 Transmission (AT/MT) & Driveline 4 01-16-2007 10:39 PM
Clutch slipping? Warranty questions....suggestions? japslapr Newbies & FAQs 47 12-25-2005 09:16 PM
Exedy sport clutch and AWD slipping questions... 98_soobie Transmission (AT/MT) & Driveline 2 11-23-2005 09:11 AM
Clutch slipping. Got a few questions. ErikAnderson North West Impreza Club Forum -- NWIC 14 10-01-2005 03:12 PM
Scoobie Noobie Question about clutch slipping..... Juustncase Legacy Forum 9 10-28-2004 07:15 PM
