Old 10-31-2005, 10:57 PM   #1
bobafett
Member#: 10095
Default No rear lights, but have brake lights...?!?
Hey guys, quick question here. As of this weekend, I noticed my rear lights are not turning on when my headlights are on. But, when I brake all 3 brake lights go on.
Any idea why this could be happening? Could the bulbs be out? Are they separate bulbs from the brake light bulbs?
I'm not driving it until I get this cleared up (I suppose I'll have to take it in, but on the off chance I can fix it otherwise, I'd like to do so)...
Thanks!
bobafett is offline   Reply With Quote
Old 11-02-2005, 02:04 PM   #2
bobafett
Member#: 10095
*bump*
Old 11-02-2005, 04:07 PM   #3
sjl1614
Member#: 56791
06 OBS
Did you check all your fuses? The brake and tail light should be same bulb with 2 filaments, it's possible both are burned out. Start with bulbs then check fuses.
sjl1614 is offline   Reply With Quote
Old 11-03-2005, 12:26 AM   #4
bobafett
Member#: 10095
Thanks for the post...
I checked my lights tonight and they are working fine now
Old 11-06-2005, 01:30 AM   #5
e28fixer
Member#: 25037
I drive an '02 wagon and had the same problem. Turns out the culprit was a loose harness plug in the center rear of the cargo space under a piece of plastic trim. It finally worked itself loose completely and I got stopped by a local cop for my lights being out. The harness ran from the front and split left and right at the plug to provide power to the lights. Good luck.
Scott
e28fixer is offline   Reply With Quote
Old 11-06-2005, 04:25 AM   #6
bobafett
Member#: 10095
Thanks! They seem to be working now, but I will check that area...
how to disconnect daylight driving lights but have low beams? scoobypuff Interior & Exterior Modification 25 04-19-2010 10:09 PM
WTT: My STi rear panel for 2.5i/WRX rear panel w/3rd brake light freshADR SCIC Private Classifieds 9 03-06-2008 07:01 PM
WRX Rear Deck Carpet w/Brake Light ChrisM623 MWSOC Private Classifieds 1 12-18-2006 02:43 PM
need rear parcel deck/3rd brake light njskatchmo Tri-State Area Private Classifieds 3 01-28-2006 12:09 PM
i REALLY want jdm lights but have no money, anything else look good? hangten93 Interior & Exterior Modification 7 06-12-2004 06:50 AM
