11-01-2005, 11:43 AM | #1 |
Member#: 41180
Vehicle:2002 WRX WRB |
Target boost after AP map change
Was just wondering about how long it takes to get the car to hit target boost after changing the RT map. I did this yesturday and now can only hit about 13psi.
11-01-2005, 11:46 AM | #2 |
Member#: 80663
SWIC
Vehicle:2005 STi |
Should be instant. Which map were you using and which did you switch to?
11-01-2005, 11:55 AM | #3 |
Member#: 41180
Not sure wich map was in the car. Just got in about a week and half ago. Put in the stg 2 93 oct.
11-01-2005, 11:59 AM | #4 |
Member#: 80663
SWIC
Vehicle:2005 STi |
Do you have a full Turbo-back exhaust? Is the gas in your tank 93 octane?
11-01-2005, 12:02 PM | #5 |
Member#: 41180
Yes and yes, actualy it has the up pipe to. It has an Injen cold air intake and a TXS bov, could one of them be affecting it. BTW both are being changed for the stock parts soon.
11-01-2005, 12:11 PM | #6 |
Member#: 80663
SWIC
Vehicle:2005 STi |
I don't know what problems it causes, but I know that BOVs are generally not a good idea with stock turbo WRXs. Check all the connections between the turbo and the IC and from the IC to the manifold. Switch over to the stage 1 realtime and/or the stock realtime map and compare boost levels. If the boost does not get higher, then your problem is likely mechanical and not with the AP.
replacing the BOV with the stock componant would be another important thing to do. |
11-01-2005, 12:22 PM | #7 |
Member#: 41180
Im prob putting the stock BOV on this afternoon, and should be getting a stock intake next week. Thanks for the advice. Ill look into it all this afternoon
11-01-2005, 01:16 PM | #8 |
Member#: 80663
SWIC
Vehicle:2005 STi |
sounds good, lemme know how it all goes. If you do want increased airflow that is safe, a good panel filter would work well. I use an Airraid...just make sure when you clean it you don't use too much oil or that will foul up the MAF sensor.
11-02-2005, 02:26 AM | #9 |
Member#: 41180
Hey thought id give you the update. So while i was changing the bov back to stock i noticed that the intercooler was moving a bit. Come to find out the clamp on the TB side of the coupler wasnt tight at all, flick it and watch it spin loose. So i tightened that up, got the bpv on and reset the computer. Now the car hits 16psi without any problem. Im acutaly at full boost before 3500. So needless to say that car pulls like crazy now. Guess little things like that are what you find when you buy a car used, only got it like a week and half ago and havnt really had a chance to got over the less obvious stuff.
Target boost for AP Stage 1 | efiniluvr | Newbies & FAQs | 4 | 06-25-2007 08:25 PM |
Not hitting target boost on stage 1 map | Mr.Krinkle | Commercial ECU Reflashes | 18 | 06-16-2007 06:04 PM |
Not hitting target boost after ebay tmic install | le wagon | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 19 | 08-21-2006 02:34 PM |
question about AP cal 91 oct map and target boost (possible problems) | bubba03wrx | Engine Management & Tuning | 3 | 03-08-2005 05:12 AM |
Not hitting target boost after an installation :( | rukkie | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 09-15-2004 02:07 PM |
