Old 11-01-2005, 02:26 PM   #1
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Default CEL-02 Heater Circuit (Happens even after sensor replacement)
My 95 Impreza 2.2 which happens to be OBD-II has been throwing a pair of the exact same CELs. PO135 O2 Heater Circuit Malfunction (Bank 1 Sensor 1).
I replaced the front O2 sensor and receive the same 2 codes. I have both cleared the code with a scanner and reset the ECU by disconnecting the battery.
Wiring is what comes to mind first but I checked to make sure things were secure where the sensor plugs into the harness in the engine bay. I have seen before where pins have backed out of those connectors. I made sure that wasn't the case with this one.
Any help would be great.
Thanks
Brad
MY99 2.5GT is offline   Reply With Quote
Old 11-01-2005, 03:40 PM   #2
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
I'm pretty sure the "test" for an O2 heater circuit is looking for the correct resistance value between the two O2 heater wires. Perhaps one of those wires has broken or a connection has corroded.
Unplug the connector in the engine bay, use a multimeter on the two pins (sensor side) leading to the heater, and measure the resistance. If none, you've got a short; if very high, you've got a broken wire or bad connection.
Also, be sure you're dealing with the correct O2 sensor.
Old 11-01-2005, 05:23 PM   #3
JimBlake
Member#: 82247
2005 Saab 9.2x Aero
satin grey
Also, NEITHER SIDE of the heater should have any continuity to ground.
JimBlake is offline   Reply With Quote
Old 11-01-2005, 08:56 PM   #4
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
PO135 is the code for front 02. The car is running fairly smooth but is getting a little worse mileage then before the CEL. I will troubleshoot the wiring on my brand newly installed sensor this weekend.
Brad
CEL P0031 front 02 heater a/f ratio sensor low voltage shinsain Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 11-09-2011 09:06 PM
P0031 H02S heater control circuit low (bank 1, sensor 1)? AjntOrnj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-28-2009 04:58 PM
P0037 Rear oxygen sensor heater circuit malfunction shady Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 01-19-2008 08:42 PM
O2 Sensor Heater Circuit Malfunction? RyansJDMgc8 Service & Maintenance 4 10-30-2004 05:50 PM
o2 Heater circuit malfunction CEL RyansJDMgc8 Normally Aspirated Powertrain 0 10-27-2004 03:00 AM
