Old 11-01-2005, 05:19 PM   #1
2.5 Blue Roo
Member#: 45727
GrpB UrQ Lancia
205 GTI
Default Where did you mount your Emanage?
im looking for a spot to mount mine, any suggestions?
2.5 Blue Roo is offline   Reply With Quote
Old 11-01-2005, 05:20 PM   #2
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
glove box
Hitokiri is offline   Reply With Quote
Old 11-01-2005, 06:41 PM   #3
Joncas
Member#: 5349
same here
Joncas is offline   Reply With Quote
Old 11-01-2005, 08:17 PM   #4
darioc
Member#: 35695
02 RST
98 Outback 92 Wrangler
im going to tidy mine up and secure between the pass seat and the center thing near the e-brake, so you cant see it.
darioc is offline   Reply With Quote
Old 11-01-2005, 08:31 PM   #5
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
I zip tied mine under the passanger seat.
ai42 is offline   Reply With Quote
Old 11-01-2005, 11:08 PM   #6
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
glove box as well
Derk1127 is offline   Reply With Quote
Old 11-02-2005, 05:53 AM   #7
redwagon
Member#: 2181
2008 SpecB
Under the passenger seat, on my amp rack. Passenger side door sill has that plastic cover to stash the wiring under for protection.
redwagon is offline   Reply With Quote
Old 11-02-2005, 11:16 AM   #8
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
I ran the wiring under the carpet and under the passenger seat. There's a hole there where the vents are under the seat. I just popped the harness plugs out that hole and plugged the emanage in.
-Brett
ExecNav is offline   Reply With Quote
Old 11-02-2005, 02:19 PM   #9
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
glove box but it sucks in the summer if you leave the car in the sun, the emanage gets pissed off and the car wont run right. it wont process the MAF signal at all.
Kawikid20o2 is offline   Reply With Quote
Old 11-02-2005, 03:08 PM   #10
GotTurbo
Member#: 64186
1998 A MONSTER
SOON BMW STEEL GREY
im voting for the glove box all the way
GotTurbo is offline   Reply With Quote
Old 11-02-2005, 05:29 PM   #11
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
can you spot it? hmmm
GregBolby is offline   Reply With Quote
Old 11-03-2005, 04:03 AM   #12
tony_subaru
Member#: 22742
My friend did his under the passanger seat. Bolted it down. Only thing is it's a pain in the butt to plug the laptop into it to tune and such.
tony_subaru is offline   Reply With Quote
Old 11-03-2005, 09:40 AM   #13
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
velcro'd to the carpet under the passenger seat, wires run underneath the carpet.
lotusTT is offline   Reply With Quote
Old 11-03-2005, 09:01 PM   #14
v_dubs37
Member#: 73288
2002 2.5 RS
Dark Blue
hows the tuning been with the e-manage? I heard they are pretty over rated.
v_dubs37 is offline   Reply With Quote
Old 11-03-2005, 10:23 PM   #15
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Love it. I'm able to max out my airflow meter at 4.8V with 14psi (2.0 block and 2.2 heads) the thing has smooth air/fuel numbers too. 15.2 idle. 14 cruising, gets down to 10.8 when I get into it.
I have ran it for almost 2 years now.
Chad
subachad is offline   Reply With Quote
Old 11-04-2005, 12:01 PM   #16
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
I've got mine under the passenger seat too.
Where did you mount your tweets?? Stevins Car Audio, Video & Security 11 04-08-2003 05:36 PM
Where did you mount your HID ballasts? buymeasti Electrical & Lighting 11 03-15-2003 11:24 PM
where did you mount your scramble boost switch? wrxtuner02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-12-2002 10:39 PM
Poll: Where did YOU mount your crossovers? stimpy Car Audio, Video & Security 8 10-23-2000 03:27 PM
S-AFC Where did you mount yours tmaler13 Technical Forum Archive 1 09-02-2000 11:54 AM
