11-01-2005, 05:24 PM | #1 |
Member#: 51243
Vehicle:2004 Subaru WRX STi WRB - GTX30r |
Wideband mounting Location and Sensor Life
Reading over the various post concerning the mounting location of the wideband o2 sensor some say a few inches after turbo in the downpipe. While others have them mounted toward the end of the downpipe before the midpipe and some in the stock rear location before the CAT.
For the bosch sensor that is supposed to be ~700-750C operating temps my question is: Has anyone ever tried to measure the temps on a aftermarket downpipe to determine which mounting location is better, the first few inches or the last few inches of your downpipe? (or some other location) Also for those out there that have mounted there wideband in one of these locations could you comment on how long the sensor has lasted and if you feel your getting accurate readings from the sensor mounted in that location. Thanks Travis
11-01-2005, 05:33 PM | #2 |
Member#: 21980
NESIC
Vehicle:2002 PSM WRX (Sold) 2017 BMW X5 |
I had a sensor mounted in the bottom of a short downpipe (basically right after the bend closest to the ground) for something over 15k miles. Sensor never had problems and gave accurate readings to the end.
Edit: the sensor never died I just removed it and sold the unit. Last edited by cdvma; 11-01-2005 at 07:58 PM. |
11-01-2005, 05:39 PM | #3 |
Member#: 60324
Vehicle:1998 RS |
I've had my bosch sensor installed in my helix v1 DP for over a year with 25K miles with no issues. This location is near the end of the DP (it's catless). I do notice a slight delay in the reading, but it's VERRRRY slight. I think for tuning you want it next to the turbo, for daily driving i'd move it farther away to prolong the life of the sensor.
11-01-2005, 07:31 PM | #4 |
Member#: 15350
Vehicle:2002 WRX Sedan Midnight Black |
I had my Bosch mounted about 6" after the turbo and the first one lasted me about 15K miles before it pretty much completely crapped out and would give timing sensor errors on the LM-1 after 1-2min of operation.
I'm on my second one now. -jason |
11-01-2005, 08:28 PM | #5 |
Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 2006 Wrangler Sport |
For those who mount it closer to the turbo, have you installed a smaller copper heatsink for it? It is said to protect the sensor when it is installed on a pipe that is hotter than recommended. For the heatsink, it's really easy to make...
-goto HomeDepot or Lowes -buy a short length of 1"ID Copper pipe from the plumbing section -clamp it in a vice and use a hacksaw to cut the pipe along its length -use a couple screwdrivers like levers to open the pipe up -keep getting it more and more open until you can get it wide enough to hammer it flat (or use pliers/vice/whatever to flatten it) -drill a hole in the middle big enough for the sensor -fold up the edges like shown: |
11-01-2005, 08:53 PM | #6 |
Member#: 49087
RMIC
Vehicle:1998 RST V8 STi swap '05 R6 '95 BMW V8 hotness |
I've never heard of using a copper heat sink. The hot gas exchanging through the ceramic is what screws up the sensors. I can't really see how having a heat sink on the body would help keep the ceramic cool enough during quick WOT bursts.
I prefer the end of the DP for WB sensors. WB sensors use a pressure/temp reference to calculate lambda. The turbulance right after the turbo outlet can skew these readings a bit. As long as there is sufficient heat present to keep the ceramic happy the readings will be accurate no matter where they're placed. Keep in mind that the hot gasses are moving VERY VERY fast as they're leaving the turbo. There won't be any signifigant latency with the sensor by moving it an extra 18" or so. |
11-02-2005, 02:58 AM | #7 |
Member#: 1366
VIC
Vehicle:2000 RS-T -> RSTi-8 Blue Ridge Pearl |
I would say mine is somewhere between 1' to 2' from the turbo and from what I have gathered, lag is nothing to worry about when you're mounting it on the downpipe - heat is a bigger problem
11-02-2005, 10:12 AM | #8 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
i put mine in the oem rear o2 location.
fhi knows best. |
11-02-2005, 11:24 AM | #9 | |
Member#: 7194
Vehicle:2011 997.2 Turbo Black |
11-02-2005, 11:32 AM | #10 | |
Member#: 14164
TXIC
Vehicle:2023 Model S Plaid Hailed 02 WRX Wgn |
http://www.innovatemotorsports.com/x...cat=250&page=2 |
11-02-2005, 05:47 PM | #11 | |
Member#: 9794
TXIC
Vehicle:02 2.5LWRX-Retired 335i w/twins |
fwiw, I put mine at the VERY beggining of the MP, right after the DP flange (before catback section). |
11-02-2005, 06:21 PM | #12 | |
Member#: 7327
NWIC
11-02-2005, 06:55 PM | #13 |
Member#: 95840
NWIC
Vehicle:sold to a good bud awaiting next car |
nhluhr...where do you have your wideband installed at?
11-02-2005, 08:31 PM | #14 |
Member#: 51194
Vehicle:2004 JDM WRX 530whp Mustang dyno |
I have mine in the botton of the downpipe right before the second bend in the verticle section. This prevents it sitting in a condensation collecting area like after the second bend in the DP. This is supposed to extend the life. Used the bosch for over a year and teh VW for the last 4 months. It seems happy there.
11-02-2005, 11:37 PM | #15 | ||
Member#: 21980
NESIC
11-03-2005, 04:44 AM | #16 | |
Member#: 7327
NWIC
11-03-2005, 07:51 AM | #17 | |
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
Its principle of operation is similar to that of their tailpipe sniffer mount and they're both covered by a pending patent, US 20050160840. If you want to look at the diagrams in that patent, you'll need a TIFF browser plugin. The free one from www.AlternaTIFF.com works well. Last edited by Jon [in CT]; 11-03-2005 at 09:01 AM. |
11-03-2005, 09:58 AM | #18 | |
Member#: 62211
South East
Vehicle:03 WRX Sonic Yellow |
If I've understood that properly......am I looking to mount it INTO the exhaust flow or away from the exhaust flow. For clarity.....say I'm mounting it in a downpipe which is pretty much verticle....would I want to mount the sensor pointing slightly UP, pointing into the flow, or slightly DOWN, pointing away from the flow? |
11-03-2005, 10:16 AM | #19 | |
Member#: 2992
NESIC
11-03-2005, 10:33 AM | #20 | |
Member#: 62211
South East
11-03-2005, 12:32 PM | #21 |
Member#: 88322
Vehicle:2009 BMW 135i |
Why would you not what it parallel? And when you say perpendicular, do you think it matters if that is straight up from below, or straight down from above?
I always thought that the side was a good spot. Most bungs in aftermarket exhaust systems I've seen are this way. And I thought mounting it from underneath was a bad idea because it would clog and collect particulates faster. I don't see a problem mounting it from above pointing down, nor from the side. I'm not doubting, but care to explain why? |
11-03-2005, 12:46 PM | #22 |
Member#: 21980
NESIC
You don't want it parallel with the ground because of condensation...read the last 6 posts before yours.
11-03-2005, 01:19 PM | #23 |
Member#: 88322
Ehh, that makes no sense. Why would condensation form on the sensor electronics if it were mounted parallel to the ground, but not vertically? What do you mean "far end of the sensor body"? I guess I'm not quite following...
11-03-2005, 01:30 PM | #24 |
Member#: 21980
NESIC
See the last two pages of the TXS Tuner user manual. It has a copy of the Bosch sensor install docs which diagram it and say the same thing about condensation during startup.
http://www.turboxs.com/downloads/TunaUserManual_1v1.pdf |
11-03-2005, 02:05 PM | #25 | |
Member#: 2992
NESIC
SOLD: Innovate Motorsports LC-1 Wideband O2 Controller and Sensor, XD-16 Display | lancelucas | NWIC Private Classifieds | 4 | 05-19-2010 05:47 AM |
SOLD: Innovate Motorsports LC-1 Wideband O2 Controller and Sensor, XD-16 Display | lancelucas | Engine/Power/Exhaust | 4 | 05-19-2010 05:47 AM |
Wideband O2 sensor mounting location | Airboy | Canada Region Forum | 2 | 10-11-2006 12:41 PM |
FS in MD: AEM UEGO wideband 02 gauge and sensor | lowblow | Private 'For Sale' Classifieds | 12 | 01-13-2006 11:47 AM |
Wideband sensor types, locations, and readings | Kha0S | Engine Management & Tuning | 9 | 12-11-2003 02:54 PM |
