Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 11-01-2005, 05:39 PM   #1
Member#: 38338
2003 Outback Sdn H6
Default to anyone w/a wrx swap into their rs using rs tranny and lightened flywheel:
i have a 2000 rs with 02 wrx swap, using the rs tranny. i have an act clutch and act streetlite (13.8lbs or whatever), and i get lots of misfires. i know this is normal for the wrx motor, but how often are you guys getting misfires (like, flashing cel's, not solids)? mine does it at least once every other day or every day sometimes. when it does flash the motor sputters and stuff, and i'm not sure if this is because of the flywheel or some other issue i'm having. i'm wondering if because the combo of the flywheel with the shorter gearing of the rs tranny vs. wrx tranny is really bad for the motor...?
legacy2003 is offline   Reply With Quote
Old 11-01-2005, 09:29 PM   #2
Member#: 48377
1996 Gutted, built
XP class Impreza L
It's not the flywheel or the Tranny gearing.
You are actually getting misfires. Check your wiring, plugs, coilpacks, and look for stray grounds. Misfires can be very bad on an engine. Try to get this fixed right away.
When someone with a lightened flywheel gets a misfire code it's because the ECU can't tell the difference between a real misfire and the larger deacceleration between fires caused by a light flywheel.
speedyHAM is offline   Reply With Quote
02 wrx swap into a 99 GC. Tranny issue.. scubydrew414 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-04-2011 09:52 PM
2002 WRX swap into 2001 RS swap question dtl1218 Subaru Conversions 14 08-13-2008 01:58 PM
tower strut to fit WRX swap into RS Jonnathan Built Motor Discussion 0 07-31-2007 04:24 PM
02 Wrx Swap Into A 99 2.5 Rs What Cani Use What Cant I GODSON Subaru Conversions 10 10-12-2004 03:56 PM
wrx swap into RS auto gasser Subaru Conversions 6 07-10-2003 11:57 AM
