Old 11-01-2005, 06:16 PM   #1
markadopolus
Member#: 69586
Default Help with IC water spray wiring
OK you electrical gurus..... I have a wagon and I am trying to use the 2nd (rear wiper) pump as my IC spray pump. I have the nozzle, and hose set up, I just need to install the wiring and switch.
I have an OEM sti switch that I want to use. Do I need a relay to do this, or can I just use the switch for a ground and hook the pump up to the battery with an inline fuse?
I drew up a couple of diagrams. Please correct me if I am wrong with any of this.
With relay
Without relay
markadopolus is offline   Reply With Quote
Old 11-01-2005, 10:11 PM   #2
markadopolus
Member#: 69586
anyone?
Old 11-02-2005, 10:32 AM   #3
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
The first diagram looks like your best bet. I don't know what kind of power draw the wiper bottle pump needs, but i'd still use a relay to be safe.
However, i'm not sure what pin does what on the switch. Is the switch a momentary switch? From what i can tell though the line labeled "illumination" is where you're drawing power to activate the relay and the "ground" wire is required because of the bulb in the switch.
[in my opinion, the second diagram just looks wrong unless you're trying to make the grouding wire switched...]
Old 11-02-2005, 01:28 PM   #4
markadopolus
Member#: 69586
Thats what I was thinking. I read somewhere on a thread that if you use an STi switch, pin 1 and 2 are ground, pin 3 goes to the pump and pin 6 illuminates teh switch.
Old 11-07-2005, 07:30 PM   #5
markadopolus
Member#: 69586
OK, so I wired everything up with the relay and it wasn't working. The switch illuminated, I know that the pump is good, but it wasn't working. I then hooked it up like the second diagram (without the relay) and it worked.
Could it be a bad relay? Is it bad that only the switch is grounded?
Old 11-07-2005, 08:36 PM   #6
Psydotek
Member#: 44168
2003 Yellow WRX
Make sure you have a good ground on the pump. And that the fuse isn't blown already.
Old 11-07-2005, 08:49 PM   #7
markadopolus
Member#: 69586
Ground on the pump is good and I checked the fuse twice. I went all obsessive compulsive on the wiring with the heatshrink tubing and whatnot. I am 99.9% positive that all the connections are good.
Old 11-10-2005, 03:27 PM   #8
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
i didnt use the relay either. could not get it to work with it, but has been on car for over a year with no problems.
StarDogChampion is offline   Reply With Quote
Old 11-10-2005, 09:39 PM   #9
AndyWRXWG
Member#: 23784
2005 M3
Tiag
why can't you just use it like you are turning on the rear washer? does the switch have some sort of different settings that make it operate differently?
AndyWRXWG is offline   Reply With Quote
Data points: impact of IC water spray on IC temps scooterforever Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-11-2005 02:43 PM
Convert IC water spray to Water Injection? wgknestrick Water/Methanol Injection, Nitrous & Intercooler Cooling 1 09-24-2003 09:04 AM
help with pressure switch for IC water spray Penguinking Electrical & Lighting 5 07-30-2003 12:25 PM
up-pipe, ebc/mbc or IC water spray? codean Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-25-2002 07:34 PM
IC water spray setup, Cheep, any thoughts? thepas Technical Forum Archive 6 05-20-2000 08:38 PM
