Old 11-01-2005, 07:08 PM   #1
paperchasin
Member#: 57117
2004 STi
Default P2093 & P2089 code pulled, need input
So i had these codes pulled by the dealership...they told me to get blah blah replaced, etc. did a search on here and didnt come up with much....heres wut the DTCs mean:
P2089 : OCV Solenoid Valve Signal A Circuit Short (Bank 1)
P2093 : OCV Solenoid Valve Signal A Circuit Short (Bank 2)
anyone have a resolution for this?? dealership says that since i was reflashed with COBB it will not be covered under warranty...one of the threads in my saerch mentioned something about a loose ground point somewhere...any input would be greatly appreciated...thanks
paperchasin is offline   Reply With Quote
Old 05-05-2006, 03:46 PM   #2
wrxtremest
Member#: 109420
2004 WRX
Black Java Pearl
I'm having the same problem
wrxtremest is offline   Reply With Quote
Old 07-19-2006, 12:32 PM   #3
anzu
Member#: 42154
2008 WRX STI
I'm having the same problem as well.
anzu is offline   Reply With Quote
Old 03-13-2007, 02:35 PM   #4
Scootaru
Member#: 36348
2003 Impreza WRX
I'm having the same problem as well. It started coming in after I put on the Perrin BigMaf intake, i think. I don't see any loose wires.
Scootaru is offline   Reply With Quote
Old 03-26-2007, 04:47 PM   #5
Scootaru
Member#: 36348
2003 Impreza WRX
I got my problem fixed. I should mention this is on my 04 STI. Accompanying the CELs, I was also having a rough idle. A friend who works at a shop looked up the codes and emailed me a TSB that may fix my problem. I later found it on Scoobymods as well: http://www.scoobymods.com/forums/showthread.php?t=5782
I removed the filters from the union bolts on the OCV and after an oil change, the CELs went away. Also, it turns out my AVCS wasn't working and that fixed the problem there, too.
Old 05-28-2007, 01:22 AM   #6
LeeC
Member#: 97843
9.87 Supra:14 Tundra
c6 z06:Blaze Yellow 02!
Sorry if I'm sort of bringing this back from the dead, but I just wanted to post this info for anyone that is still having this problem
http://forums.nasioc.com/forums/show...ighlight=P2093
I was throwing these codes, and it WAS caused by the ground on the IM on the driver side, I was having rough idle, and smelling gas, but thats a different issue =/
CN: If you have these codes, check your grounds!
LeeC is offline   Reply With Quote
Old 02-28-2012, 04:14 PM   #7
kariusvega
Member#: 269611
2005 WRX STi
great fix thanks
kariusvega is offline   Reply With Quote
FS : St. Louis 2005 STI longblock, good compression. Just got pulled need it gone!!! deuce189 Engine/Power/Exhaust 10 06-05-2010 03:33 PM
CEL code pulled, need help Ryan314 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-09-2007 08:04 PM
Car Pulls Left Input Needed aspenwhitewrx Brakes, Steering & Suspension 22 12-03-2004 03:49 PM
Pulling the motor this weekend, need input? positivePSI Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-27-2004 06:20 PM
Pittsburgh CEL code pull needed 2k2 Mid Atlantic Impreza Club -- MAIC 13 08-04-2003 07:37 PM
