Closed Thread
Old 11-01-2005, 08:46 PM   #1
baziotes
Member#: 99142
Default Disable dinger for seatbelt/door??
How do I disable the dinger for when the door is open or the seatbelt is not on...it's super annoying! 2006 WRX
baziotes is offline
Old 11-01-2005, 08:47 PM   #2
markadopolus
Member#: 69586
Take the keys out of the ignition and wear your seatbelt.
markadopolus is offline
Old 11-01-2005, 09:07 PM   #3
vulwizard
Member#: 21979
2006 STI
Obsidian Black Pearl
Default Belt Minder
Yes, The damn beeping when the seatbelt is unbuckled is pissing me off too. Just another damn babysitter factory mod like ironing the warning labels to the sun visor. Still looking for the oh so secret disable function.
vulwizard is offline
Old 11-02-2005, 12:04 AM   #4
brranger
Member#: 99197
2006 WRX 6 speed
hey i found out that all u need to do is turn the igntion on while not turning so far to start motor, and within 30 seconds u buckle and unbuckle about 20-25 times. Now on after that it just chimes like 5 time beeps right when u start the car then stops for the beeps while door is open i don't know yet.
brranger is offline
Old 11-02-2005, 04:09 PM   #5
idealrides
Member#: 10314
03 WRX 325hp SOLD!
06 Jeep SRT8 - 450hp
reach up under the steering wheel and unplug the "integrated module" - it's a small black box. pry open the box and put a piece of electric tape over the piezo speaker. or rip out the speaker if you never want to hear it again. with the tape, it's much quieter and still functional, yet removable.
3 years ago I thought the first mod to my WRX was going to be hardwiring my V1 but before I finished doing the V1 the dinger was so annoying it became the first mod.
idealrides is offline
Old 11-02-2005, 04:25 PM   #6
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Your setup is different than the original poster.
In order to disable it "permanent'y" (until the battery is disconnected), do this all within 30 seconds:
Open and close the drivers side door. Turn the key to the on position. Buckle and unbuckle the seatbelt 20 times within 30 seconds. Remove the key and open the door. Then, start the car. The seatbelt chime will go off 5 times (every time it is started) and then no more while driving.
HINTS: Never fully take the seatbelt out of the buckle. Release it and put it right back in. Also, make sure you count when the seat belt is released, not when you put it in.
Oh, and the door chime and the seatbelt chime are two different things
RexyGirl is online now
Old 11-04-2005, 11:30 AM   #7
vulwizard
Member#: 21979
2006 STI
Thanks rexygirl,
I followed your instructions and it worked great. Next mod DRL delete. Anyone know if Dash lights will still be lit at all times with DRL shut off?
Jim
Old 11-04-2005, 01:06 PM   #8
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
I wish there were a way to disable the door chime - that one gets to me more than the seatbelt one
Hank3 is offline
Old 11-04-2005, 02:37 PM   #9
RexyGirl
Member#: 63616
with mods :)
Do you drive with your door open???
Old 11-04-2005, 03:22 PM   #10
DeKaP
Member#: 90627
2005 Impreza WRX
Originally Posted by vulwizard
Thanks rexygirl,
Jim
i just did this yesterday, dash lights still work, its only one plug straight for the drls, i didnt notice anything not working, just take the screws off and take the glove box off and its a white plug, make sure you get the right one,
they say you could reach it without takin the box off but i had hella trouble so i took it off anyway, like 8 screws, pretty straight foward
heres pics
http://forums.nasioc.com/forums/showthread.php?t=843079
DeKaP is offline
Old 11-04-2005, 03:31 PM   #11
Hank3
Member#: 16157
'03 Mazda P5 <><
Not quite, but when I'm detailing the inside of my car and would like to listen to tunes, it's a pain to have to listen to the ding-ding-ding-ding-ding-ding-ding-ding-ding-ding...
Hank3 is offline
Old 11-04-2005, 03:39 PM   #12
RexyGirl
Member#: 63616
with mods :)
I was just being a smarty....Isn't there a button towards the front of the door on the frame that causes the light and the door chime? Couldn't you just prop something against it to keep it quiet?
Old 11-04-2005, 06:02 PM   #13
Hank3
Member#: 16157
'03 Mazda P5 <><
I know you were
I don't know if there is a button to activate/deactivate the door chime and light. Haven't looked into it before. Hard to believe since I've had the car for close to four years now. Perhaps I've been that annoyed with it
Hank3 is offline
Old 07-19-2007, 01:33 AM   #14
razorblades192
Member#: 154391
I just bought a 07 Impreza RS and i tried the whole unbuckle 20 times in 30 seconds trick and it worked until i shut the car off and started it again, then it was back, any ideas?
razorblades192 is offline
Old 07-19-2007, 01:53 AM   #15
busygettingthere
Member#: 153962
13 WRX limited
un-bolt your seat tip it back and un-plug the connecter from the seatbelt female side.
take the door switch out of the b-pillar un-plug it and put it back in
UNPLUG THE ****...
busygettingthere is offline
Old 07-19-2007, 05:28 PM   #16
joecerv
Member#: 110459
2006 Impreza 2.5i
Steel gray metallic
Although you brought back an old thread, I will go ahead and try to help.
If the procedure was done correctly, after starting the car, you will hear the beeps, but, the beeps will stop after the first few and does not come back.
If the battery is disconnected, the procedure needs to be done again.
PS: The answer to the OP is found in post #5.
joecerv is offline
Old 07-19-2007, 09:12 PM   #17
RexyGirl
Member#: 63616
with mods :)
correct...the first initial beeps will still be there, but then it should stop and not occur again. You can't disable the first few beeps.
Old 08-30-2007, 03:40 PM   #18
rimuladas
Member#: 76561
2005 WRX STI STG 2
WRB /gold
So no way to disable the open door chime? I like to be able to listen to tunes with the door open, and the dinging is driving me batty.
rimuladas is offline
Old 08-30-2007, 04:46 PM   #19
Pohenegamook
Member#: 134262
9 조 ☼
Compiling Android: Zagnut
In my old buick, the 'button' was near the hinge (a pillar) so I'd jam a rag or whatever in there to kill it when detailing.
But busygettingthere already almost answered your question:
UNPLUG THE ****...
And actually, I'd short it instead of just unplugging it. I haven't done this but I assume it's a 'Normally Open' switch which here means it's only closed (connected) when your door is closed. Shorting the wires will make your car think your door is closed. Someone correct me if I'm wrong.
Not sure what busy's seatbelt comment is about - I think killing the belt chime but for that I'd just do the 'jam it in 20 times in 30 secs' method.
I'll keep my eye out for a new "So I disabled my door chime and locked my keys in the car " thread
razorblades192 - thank you for reviving an old thread and not further cluttering NASIOC with dupe threads. I'm a proponent of reviving old relevant threads!
Pohenegamook is offline
Old 08-30-2007, 05:14 PM   #20
freeman.matt
Member#: 106540
2002 WRX Wagon
Blue blue blue
This was my door chime delete thread. It's an 02 though so your mileage may vary. Instead of completely silencing the chime, I rerouted the 'key-in' signal to light up a red LED behind my driver's lock button. It's rather pink in the daylight, but in the evening the lock icon is real red, and it has saved me from a lock out a time or two.
freeman.matt is offline
Old 08-30-2007, 05:42 PM   #21
joecerv
Member#: 110459
2006 Impreza 2.5i
Steel gray metallic
The one downside to these ideas is that if the door is open while the alarm is activated, it will not go off, because the system reads the door as closed.
True, very true.
If the key is left in the ignition, and all doors are locked, even with remote in hand, it will not open the doors.
If someone goes with the chime delete mod it is best to carry the spare key all of the time.
joecerv is offline
Old 09-13-2007, 11:56 PM   #22
spidercran
Member#: 128124
2006 Impreza
Steel Gray Metallic
i just tried the seatbelt thing 10 times and i cant get it to stop beeping at me, i have an 06 2.5i. what can i do? anyone!?
rexygirl? you still around?
spidercran is offline
Old 03-06-2008, 04:19 PM   #23
figgskzoo
Member#: 82547
2010 Forester
worked on my MY'07 Outback...this was vexing me more than anything else in my car...including that STUPID eff'n Electronically Controlled Throttle...well, maybe not quite as bad as that.
figgskzoo is offline
Closed Thread
Disable dinger for seatbelt???? dahane Electrical & Lighting 3 10-25-2010 04:48 PM
Policing for seatbelt usage perhaps? SlideWRX Mid West Subaru Owners Club Forum -- MWSOC 44 05-29-2005 11:59 AM
Disabled ABS for winter JVG Tri-State Area Forum 37 12-07-2003 01:24 PM
How about a new slogan for seatbelt use? rkkwan New England Impreza Club Forum -- NESIC 33 07-16-2002 01:17 PM
Disable AWD for FWD ak47th Transmission (AT/MT) & Driveline 7 05-27-2002 10:32 PM
