11-02-2005, 02:02 AM | #1 |
Member#: 65601
Vehicle:2004 WRX World Rally Blue Pearl |
Weird timing...my car has vtec...seriously..
Hey guys,
I was out tuning my pump gas map cause it seemed kind of "flat" in the midrange. Well, it is. The boost is great, 20psi from about 4500 on, solid 10.8:1 AFR's, no knock, EGT's are fine. But you can literally feel "VTEC" in the midrange. From 4500-5500ish the timing dips down into the "+6" range, it even dips down as low as 3 degrees. My timing map is fine and in this range teh lowest it should dip to is around 16. What is causing this??? I will post maps later but my llaptop battery is dead.
11-02-2005, 10:13 AM | #2 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
which firmware are you running?
do you have any ignition timing temperature corrections enabled/configured? |
11-02-2005, 11:55 AM | #3 |
Member#: 88322
Vehicle:2009 BMW 135i |
Utec? Ap? ?
11-02-2005, 11:59 AM | #4 |
Member#: 65601
it is UTEC and it is the latest version. I am not using the temperature correction currently. I have everything set at 0
11-02-2005, 02:11 PM | #5 |
Member#: 65601
anybody? I can't seem to find out what's going on. I put the TXS base map back in and it does the same thing. the IGN Timing collum will dip to 5ish-10ish degrees from 3800-5500 rpm and the modded ignition collumn will be 15-17. This is weird stuff and it's driving me insane.
11-02-2005, 02:43 PM | #6 |
Member#: 32792
NESIC
can we get a log?
your ECU timing is low, or your UTEC timing? |
11-02-2005, 03:13 PM | #7 |
Member#: 65601
I'll post a log when I get home if I can get her up and running. My laptop doesn't have a battery or a way to get the logs to my desktop. I r out of disks.
The ECU timing is very low and the UTEC timing is still fairly low. I read other logs and see people running 18-20+ degrees in the same area mine is running 8....(on the ECU portion). I'm just lost. |
11-02-2005, 03:33 PM | #8 |
Member#: 65601
my log looks a lot like this one posted by frisco-wrx after he pulled thetiming halfway down the page
http://www.wrxhackers.com/forums/sho...highlight=vf34 the ECU is trying to run such low timing, why is this occuring? |
11-02-2005, 03:56 PM | #9 | |
Member#: 30367
South East
Vehicle:2005 Legacy GT NASA SE PTB Champ |
11-02-2005, 04:00 PM | #10 | |
Member#: 65601
11-02-2005, 06:31 PM | #11 | |
Member#: 65601
11-02-2005, 06:47 PM | #12 |
Member#: 30367
South East
cool glad to hear it
I really am happy that my GF has a serious sense of humor.... | shipjumper | Off-Topic | 12 | 05-10-2007 09:21 PM |
Have a weird ? about my car? | waitandbleed92 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 03-30-2004 12:34 PM |
"In my dreams, my car has...." | Siper2 | Off-Topic | 39 | 10-01-2002 10:56 AM |
It's weird seeing my car for sale... | gtguy | Legacy Forum | 13 | 06-12-2001 10:46 AM |
My car has a sister! Amy joins the family! | webkris | New England Impreza Club Forum -- NESIC | 15 | 08-16-2000 09:23 AM |
