Old 11-02-2005, 03:41 AM   #1
chimp82x
Member#: 70908
1998 RBP 2.5RS
EJ20 + Hydra
Question The Bloody Antenna
I'm in the process of removing my antenna to clean up some rust that's beginning to grow around it. Only problem is, I can't seem to get the thing off. I've taken out the two screws and can pull the antenna housing away from the body a bit until it snags on the antenna wire. I can't figure out how to get the antenna wire out of of the car. Anyone know how to do this? I'm gonna completely remove the antenna (and wire) no matter what, and fill in the hole, so cutting the wire to get the housing off as a last resort isn't gonna bother me too much.
Nigel
'98 2.5RS
chimp82x is offline   Reply With Quote
Old 11-02-2005, 07:15 AM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
you can usually get at the wire from the inside of the car if you pull the trim panel over the a-pillar
did you disconnect the wire from the radio? it could also be snagging on something under the dash... I wouldn't cut it unless you can pull the remaining wire out from inside the car under the dash - otherwise it will be rattling around in there.
Old 11-02-2005, 01:17 PM   #3
chimp82x
Member#: 70908
1998 RBP 2.5RS
EJ20 + Hydra
I took the plastic A-pillar piece off but still couldn't get access to the wire. It's still behind the metal. Disconnecting it from the stereo doesn't help either. Is it clipped on somewhere around the firewall? I can't figure out where it's stuck.
Old 11-02-2005, 03:48 PM   #4
STirocket
Member#: 84006
2005 Impreza WRX STi
WRB with Goldies
Oh, jeaz I'm glad that's what your problem is. From the title I thought you'd beat someone to death with your antenna.
STirocket is offline   Reply With Quote
Old 11-02-2005, 07:26 PM   #5
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
can you follow the wire under the dash over towards base of the the a-pillar - maybe you can pull it down from there (or at least find where it's hung up)
Old 11-02-2005, 08:46 PM   #6
garie
Member#: 26607
2002 wrx wagon
I am going to be doing this sooon.
post when you figure it out!!
garie is offline   Reply With Quote
Old 11-02-2005, 09:12 PM   #7
HappyIdiot
Member#: 83494
2004 WRX Wagon
Red
Originally Posted by EDM
I am sure glad my 05 has an in-glass antenna.
So does the 04
HappyIdiot is offline   Reply With Quote
Old 11-02-2005, 09:49 PM   #8
EDM
Member#: 82078
2005 WRX Wagon
EDM is offline   Reply With Quote
Old 11-03-2005, 05:06 PM   #9
chimp82x
Member#: 70908
1998 RBP 2.5RS
EJ20 + Hydra
Its pretty much impossible to trace through the A-pillar. there are only a few holes in the metal and only one spot where I can actually see the line.
Old 01-30-2006, 11:12 AM   #10
craig429
Member#: 41767
I am getting ready to paint and would like to remove the antenna. I have removed the two bolts and can only get the antennia to move about a 1/4". How does the wire get routed? I have removed the A-pillar trim and just can't see how it goes to the stereo. Does it go out of the pillar to under the dash? Or does it go to the fender and then back in? Is there a plug that will prevent the antenna from being pulled out more than a 1/4'?
craig429 is offline   Reply With Quote
Old 01-30-2006, 11:57 AM   #11
chimp82x
Member#: 70908
1998 RBP 2.5RS
EJ20 + Hydra
I still haven't taken mine out for the same reason. I assume it's clipped on somewhere inside the pillar or behind the dash.
Old 02-01-2006, 11:21 AM   #12
craig429
Member#: 41767
I found out that the antenna runs straight down from the stereo and runs underneath the drivers carpet and then up to the pillar. There is tape that holds the wire down and the carpet is stuck to the floor that prevents the wire from moving. You will have to remove the drivers kick panel and sill plate to lift the carpet. You should be able to see the wire.
New Slogan from Australian Government: "Where the bloody hell are you?" snvin Off-Topic 13 03-14-2006 10:59 PM
HELP!! mahle piston circlips, what tool to hold the bloody things? quadesl57 Factory 2.0L Turbo Powertrain 1 02-13-2006 04:15 AM
Where's the bloody ECU? Al_Smokemcrack Engine Management & Tuning 2 03-24-2005 01:05 AM
what the bloody?!? soundwave Off-Topic 17 09-11-2004 01:45 PM
Message Board Statistics All times are GMT -4. The time now is 03:44 AM.
