Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 11-02-2005, 12:34 PM   #1
MdWRX
Member#: 69636
2002 Wrx
Sedona Red
Default Problems with fogs
I did the mod to allow the fog lights to be on with the running lights and high beams. The problem is that after they have been on for awhile, with the normal headlights/running lights the fogs will shut off with an audible click, i suppose it is the relay. The green light will stay lit on the switch but the lights will be off. Usually they will turn back on within a few hours of the car being turned off. I was curious if this has happened to anyone else or if anyone knows what it could be?????
Thanks Alot
MdWRX is offline   Reply With Quote
Old 11-02-2005, 01:03 PM   #2
vwown3d
Member#: 69991
Leh Keen Approved
'68 Volvo Amazon
sounds like the relay is opening back up, havent seen this around, research a different relay possible.
vwown3d is offline   Reply With Quote
Problems with my wrx stephentodd Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-02-2010 09:53 PM
Problem with Fogs Always On mod bcWRX-02 Electrical & Lighting 5 08-24-2008 01:07 AM
Problem with fogs turning on hi beams michael24556 Newbies & FAQs 3 08-14-2008 02:21 PM
problem with 04 rex fogs ValY2J Electrical & Lighting 2 03-07-2005 12:35 AM
Any problems with using fog light switch for WI? fragment Electrical & Lighting 0 07-28-2004 04:36 PM
