Old 11-02-2005, 02:08 PM   #1
SubieWahn
Member#: 38107
2003 WRX Wagon
Default Running wires through the firewall?
I put a switch inside my car to control my driving lights - however, the wiring needs to go to the engine compartment, and I didn't know the best way to go through the firewall (so I didn't). The stock wiring goes through in a couple locations, surrounded by a rubber donut/seal thingy. Didn't want to remove/cut this in fear of damaging it.
Just wondering what people were doing in this situation. Thanks!
SubieWahn is offline   Reply With Quote
Old 11-02-2005, 02:10 PM   #2
sjl1614
Member#: 56791
06 OBS
There is a groment on the drivers side firewall kinda near the clutch master cylinder. It's easier to see without the IC in place, but you can still get to it. What i usually do is take a razor, make a cut into the center and cut out a hole for the size of your wire and reinstall the groment. You will have to feed it from the engine side, it's even harder to see from inside.
sjl1614 is offline   Reply With Quote
Old 11-02-2005, 02:21 PM   #3
Casey
Member#: 82371
2002 IMPREZA
22 psi @ 2600rpm
There is also a round hole with a cover behind your brake pedal near the floor.
Casey is offline   Reply With Quote
Whats the best place to route wire through the firewall Psyk Car Audio, Video & Security 8 09-01-2005 12:58 PM
Where to run wires through firewall? prelude/2.5rs Electrical & Lighting 6 04-06-2005 11:21 PM
Wiring through the firewall sneeky Electrical & Lighting 8 03-27-2004 11:01 PM
Running wire through firewall Dakken Car Audio, Video & Security 7 12-04-2002 08:22 AM
Where should I run wires etc. through the firewall? scootr Normally Aspirated with bolt-on Forced Induction Powertrain 2 10-22-2001 01:22 AM
