Old 11-02-2005, 03:47 PM   #1
glh37
Member#: 99367
Default check engine light
i have an 02 rs and periodically my check engine light will come on. it might stay on for about a day and then clear up for about a week and then pop up again. anyone experience the same problem or know what might be the cause.
glh37 is offline   Reply With Quote
Old 11-02-2005, 05:52 PM   #2
solbey11
Member#: 89234
Take your car to Autozone and have them pull the code. Simple as that. And the light doesn't have to be on for them to pull the code either. Your ECU stores them.
solbey11 is offline   Reply With Quote
Old 11-02-2005, 06:09 PM   #3
glh37
Member#: 99367
thanks, i wasnt sure if the light needed to be on or not.
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 12:47 PM
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-14-2003 09:04 PM
Engine coolant temp sensor check engine light? rhdude Mid Atlantic Impreza Club -- MAIC 2 11-09-2002 02:42 AM
Engine vibrating, check engine light on codemunky Service & Maintenance 2 09-15-2002 07:50 AM
