Old 08-31-2001, 03:31 AM   #1
olie
Member#: 3352
Question MSD Ignition. What will I need to make this happen?
I have a 2000 RS. And I'm trying to figure out what I will need to order to have the ignition system replaced with MSD. I know that I have the distributorless ignition, but there is a few different systems that they carry. Anyone with any experience w/ignition on they're Impreza please help me out. THANKS!!!!!!!!!
Jay "olie" Olson
olie is offline   Reply With Quote
Old 08-31-2001, 01:18 PM   #2
jacktam1
Member#: 1783
2000 2.5RS
I think you need it only if you have tons of mod..
jacktam1 is offline   Reply With Quote
Old 08-31-2001, 09:45 PM   #3
spshultz
Member#: 1415
2008 IS350
'13 SantaFe
There is another I-Club member that is using the MSD-DIS2 in his Legacy. And he said that yes, it does help.
But, I don't know of anyone using an MSD other than Tony Rigoli of TRP and they are pushing max HP and probably need it.
spshultz is offline   Reply With Quote
Old 09-01-2001, 07:12 PM   #4
slide
Member#: 1130
2013 STI Hatch
That would be me with the legacy. All you need is to find a place to mount it.. Splice in the MSD wire harness into the trigger that wires to the coil pack. Easy to install. If you can change your own oil it should take you 15 minutes. As for is it worth it. Yes on the mileage alone.
slide is offline   Reply With Quote
Old 09-03-2001, 04:25 PM   #5
SCOOBER
Member#: 223
1999 Impreza 2.5RS-T
Hey Slide,
Do you have any pics of your install? What unit did you use and are there any extra parts needed that don't come with it? Also, were in the wiring did you splice in....color, etc.
Thanks,
Doug
SCOOBER is offline   Reply With Quote
Old 09-03-2001, 11:07 PM   #6
tulit
Member#: 338
09 STi
Interested as well.
tulit is offline   Reply With Quote
Old 09-04-2001, 04:03 AM   #7
ivbdn
Member#: 2736
2001 Impreza 2.5RS
Please let us know how it works out and if it was worth it.
ivbdn is offline   Reply With Quote
Old 09-04-2001, 02:30 PM   #8
Santo Domingo 2.5 RS
Member#: 5354
Silverthorn Metallic
but, does anyone has a MSD ignition on a 2.5 RS??
not a WRX
Santo Domingo 2.5 RS is offline   Reply With Quote
Old 09-04-2001, 02:46 PM   #9
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
I recall someone having the HKS system on their RS.
Keiho is offline   Reply With Quote
Old 09-05-2001, 11:48 AM   #10
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default MAKE THAT 2 LEGACY'S
I have the MSD DIS-2 too!!! Makes a noticable difference...better acceleration, smoother, and better gas mileage...I also chaged the plugs to NGK, so that helped too I guess!!!
Pics ... you want pics .. okay you asked for it!!! Sit back and relax and enjoy the show!
http://members.i-club.com/ViewMember...90&PicNumber=2
Pics of NEW GReddy front lip and new sets of either Raybrig or Hella lights soon to be posted!!!
CRAZY KEN
CRAZY KEN is offline   Reply With Quote
Old 09-05-2001, 08:07 PM   #11
inpreza kid
Member#: 3334
ken what i want to know is how you hooked it up? like what wires did you need to splice and such?
inpreza kid is offline   Reply With Quote
Old 09-06-2001, 01:32 AM   #12
Member#: 5354
ihave seen the DIS-2 ignition sytem, on Legacys, but how about the RS, can it use the same ignition sytem? if so, how do you wire it?
What will I need to swap wrx to 6 speed subadupa Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 12-03-2008 10:12 AM
WHat will i need to get 350 to 400hp out of a 2.2t TURBO KID Built Motor Discussion 3 03-02-2008 04:10 PM
What do I need to make this AVC-R work? P-TownWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-09-2006 04:19 PM
what can i do to make this better? wrxtuner02 Off-Topic 3 02-18-2005 10:42 PM
some needs to make this pic of fishguy a owned pic joe z Off-Topic 16 11-11-2004 11:34 AM
