Old 11-02-2005, 05:18 PM   #1
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Default Swapping a 2.2t Shortblock into my NA 2.5DOHC then Turbocharge
I am having trouble with my headgaskets again, had them replaced under warranty at 59k and am now at 94k.
Anyway I have both a complete 2.2 turbo motor minus injectors, fuel hard lines, turbo and exhaust piping. As well as a running 91 turbo legacy 5spd thats in bad shape body and interior wise.
The plan is to use the 2.2 turbo block, once cleaned up and inspected, by simply swapping it into my Legacy with all other pieces remaining the stock 2.5 with WRX injectors and parallel fuel rail mod. Then build a turbo system.
Anyway specifically I was wondering what sensors in the bottom end would be effected or possibly different on the 2.2t compared to the 2.5NA? As well once the turbo system is built what modifications are needed to keep pesky CELs away?
I plan to manage the spark and fuel with a Perfect Power SMT6 and possibly manage boost with an Apexi AVCR. Also another option if the WRX injector and parallel rail idea don't work out I could add a pair of injectors in the intake stream, however I really don't want to do that unless I run Water or Alchy injection.
Any info/thoughts will be helpful.
Thanks
Brad
MY99 2.5GT is offline   Reply With Quote
Old 11-04-2005, 11:46 AM   #2
JoshP
Member#: 94350
isnt there only one sensor in the bottom end anyway? crank position?
JoshP is offline   Reply With Quote
Old 11-04-2005, 01:19 PM   #3
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Possibly. Anyone know differently?
Old 11-05-2005, 06:42 AM   #4
Natoe
Member#: 90353
Sold '95 22T Impreza
'99 EJ205 L, AE86 GVR4
crank angle sensor, cam angle (not in block obviously), and the knock sensor. then just the main water pipe sensors stuff.... thats it though
knock sensor.....you want that.
Natoe is offline   Reply With Quote
Old 11-05-2005, 11:54 PM   #5
josh...just josh
Member#: 82273
97 impreza L
now with wrx brake love!!
um...knock sensors not in the bottom end either...if i remember corectly it's right under the throttle body
josh...just josh is offline   Reply With Quote
Old 11-06-2005, 01:09 PM   #6
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
I had forgotten about knock. I guess a better way of syaing it would be its in the "middle end"
Yeah cam sensors will remain the stock 2.5 DOHCs. I guess I need to figure out if there are differences in the crank sensors. Engine managent should be able to take care of that.
Would there be any issue with using an ecu that is meant to manage a 2.5 crank on a 2.2? Just trying to figure out if it will conflict with anything.
Thanks
Brad
Old 11-06-2005, 03:17 PM   #7
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Use the timing sproket on the crankshaft from your 2.5 and stick it on the 2.2 and you shouldnt have any problems.
bmxpunk is offline   Reply With Quote
Old 11-06-2005, 08:19 PM   #8
turbocolin
Member#: 43539
95L 97L 03hedgehog
02 wag 180mph monster
arent the sprockets the same
turbocolin is offline   Reply With Quote
Old 11-06-2005, 09:28 PM   #9
bmxpunk
Member#: 89599
1995 almost 22B:)
red
I thought they were but when I was doing my swap, I was gonna put the hydra into my car, I sent the pictures of the crank sproket and the cam sproket to them and to autronic and they said that they weren't compatible wit hthe newer ignition systems, so If I wanted to run eiter the autronic or the hydra I would have to swap sprokets and get extra triggers welded onto my stock cam sprokets. I could be competely wrong though.
Old 11-06-2005, 10:03 PM   #10
turbocolin
Member#: 43539
95L 97L 03hedgehog
wondering if they had some to sell to you
Old 11-06-2005, 10:10 PM   #11
bmxpunk
Member#: 89599
1995 almost 22B:)
red
no they told me to go to a machine shop and just have them welded on. I remember looking at a wrx one. it had alot more teeth than mine does. my crank sporket only has 6 triggers (ibelieve)
Old 11-06-2005, 10:58 PM   #12
turbocolin
Member#: 43539
95L 97L 03hedgehog
yeah what heads u usin
Old 11-06-2005, 11:48 PM   #13
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
Some of the DOHC 2.5L crank sprockets will be the same, some won't. Just make sure you use your old one and you'll be fine. There's also the oil pressure sender for the warning light. I'm pretty sure they're the same between all EJ motors. It bolts into a collar near the front just off the main oil galley.
http://forums.nasioc.com/forums/showthread.php?t=865941
Cheers, Simon.
Really_Soaked is offline   Reply With Quote
Old 11-07-2005, 01:34 PM   #14
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Thanks guys hopefully Knock Sensor fitment is the same on 2.2t as the 2.5 DOHC.
I will be sure to swap the trigger sensor from my 2.5.
This is kind of obscure but I planned to source a turbo X member from one of the other various subaru turbo cars and run aftermarket WRX fitment exhaust and intake piping as well as a VF30 or 34. Since I plan to use my 2.5 DOHC intake manifold/TB does anyone know if there is a significant enough measurement difference between the WRX manifold/tb and the 2.5 DOHC manifold/tb that I would have fitment trouble with the WRX intercooler and piping from the turbo?
Brad
Old 11-07-2005, 01:53 PM   #15
turbocolin
Member#: 43539
95L 97L 03hedgehog
knock sensor is identical what heads stock na
Old 11-08-2005, 11:32 AM   #16
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Yep currently stock NA 2.5 DOHC heads. Only plan for the time being is to possibly open up some of the coolent passages to match whats in the 2.2 closed deck motor.
Any opinions on what design head gasket to go with? I have been reading about people using a similar combination to mine but are running the 2.5 head DOHC gasket. However there are 4 cooling passages that would be at least 1/3rd covered up if I used that gasket. The 2.2t gasket should match the cooling openings on the block but wouldn't match the openings in the head unless I mill the heads. Which would be better if I decided not to mill the heads. Allow the restriction to start with the gasket or use a more open gasket and allow the metal of the heads to restrict flow.
Another question I had was with the bore of the 2.2 being smaller then the bore of the 2.5 I should I use a 2.2 gasket that matches the bore sizing or would it be better to use a gasket that matches the combustion chamber size on the head? Or does it really matter? I figured common sense tells me I use the 2.2 gasket that would leave some gasket material exposed to combustion and may cause problems in the future. I might not be thinking about it right though.
Thanks
Brad
A few Engine Swapping Questions. 05 WRX shortblock into an 05 2.5rs CousinVin Newbies & FAQs 2 03-18-2010 06:13 PM
Swap 2.2t block into 02 wrx 303 sti Subaru Conversions 5 10-29-2009 11:49 PM
Swap 2.0L WRX or 2.5L WRX into my 00RS Rallly2000 Subaru Conversions 1 09-23-2008 10:32 PM
Installed my Borla header, with 3" exhaust back on my NA 2.2 reddevil Normally Aspirated Powertrain 3 04-28-2008 01:33 AM
95 jdm wrx swap into my 98 2.5rs almost done spoonfedb18a1 Subaru Conversions 2 09-30-2005 12:09 AM
