Old 11-02-2005, 04:31 PM   #1
idealrides
Member#: 10314
03 WRX 325hp SOLD!
06 Jeep SRT8 - 450hp
Default just finished LED tailight retrofit...
I've been thinking about doing this for a while but finally got around to it when I stumbled on some used stock WRX tailights on ebay for $40. After a failed first attempt to seperate the lens piece from the housing using an oven like in a headlight retrofit, I busted out the dremel and went to town, cutting a 7 inch opening along the bottom and sliding in some oval ready-to-go truck brakelights. (model#PTF-R56 from superbrightleds.com - $22 each). These lights have a more focused/precise beam pattern than the factory brake lights. If you've ever been behind a trailer truck that has them, you'll know how bright they are. They also function as taillights, at half brightness.
I also had to re-do my "stealth auxiliary reverse lights" (original post) on these new housings... this involved drilling a hole and snapping in an extra bulb socket, wired in parallel with the stock reverse bulb (in order to see better at night after installing rear window tint). This time I made a change to the setup... I used the factory direction signal socket for the "extra" reverse bulb, because it has the proper location inside the reflector housing to provide the best/greatest light output. I also used 50 watt 1157 halogen bulbs, which means I have a total of 140 watts of well-focused reverse light.
Then of course I had to move the direction signal wiring to the new socket, which is in the same reflector bay but off to the side. For these I'm using plug-and-play 1157-style LED bulbs from ledtronics. They're fairly expensive for plug-and-play bulbs - around $50 per pair - but they have integrated load equalizers to correct the bulb-out function of the signal relay, and they're very bright, especially since they have LED's mounted radially so it helps to illuminate the whole reflector housing, providing more uniform illumination.
I'll post some more pics when they're on the car....
idealrides is offline   Reply With Quote
Old 11-02-2005, 04:35 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
do you have any shots from farther away?
Shane
PARANOID56 is offline   Reply With Quote
Old 11-02-2005, 04:36 PM   #3
PhatheadWRX
Member#: 16899
they stay the same
age
nicely done
PhatheadWRX is offline   Reply With Quote
Old 11-02-2005, 04:46 PM   #4
idealrides
Member#: 10314
03 WRX 325hp SOLD!
Shane
I'll take some when they're on the car.
I'm just thinking about how to get a picture of the brakelights... if I ask my girlfriend to help take the picture, i'll have to explain this whole thing to her, then she'll be jealous that i spend more time working on my car than with her, blah blah blah.
Old 11-02-2005, 06:25 PM   #5
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
You mean you will actually be honest about time and cost to her??
offset
offset is offline   Reply With Quote
Old 11-02-2005, 06:31 PM   #6
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
nice! can't wait to see all the pictures.
RR
Rapid_Roo is offline   Reply With Quote
Old 11-03-2005, 12:22 AM   #7
idealrides
Member#: 10314
03 WRX 325hp SOLD!
bad news.... i just plugged in one of them to make sure the ledtronics bulb had a built in equalizer (according to one of the sales blubs) but it was wrong, it doesn't. This means that the direction signal was blinking fast.
The good news is that everything was otherwise wired up nice and all the lights were great. I just didn't feel like bolting them in place just to have to remove them to install the load equalizers once I get them. I'll post the finished pictures once everything is installed on the car, should be in a week or two.
Old 11-03-2005, 01:53 AM   #8
PARANOID56
Member#: 22035
2003 Brocoma DCab
i wouldnt get the load equalizers as all they are is large resistors. i would get a new electronic flasher. these flashers dont need to sence a load on them. so they dont hyper blink the lights.
Shane
Old 11-03-2005, 02:34 AM   #9
Handsdown
Member#: 29355
that is very sweet. if i had an extra set of tails sitting around i'd do this in a heartbeat.
Handsdown is offline   Reply With Quote
Old 11-03-2005, 11:54 AM   #10
idealrides
Member#: 10314
03 WRX 325hp SOLD!
Shane
i was thinking about that, but i don't know what style relay is in the car, i don't even know where it is. maybe behind the glovebox? Also by using the equalizer if one of the front halogen signal bulbs blows, it will still trigger the bulb out function.
Old 11-03-2005, 10:01 PM   #11
R_W
Member#: 76896
A Tridon EP-37 from NAPA will work. It is two pin, and the stock is 3 pin, but this is not a problem. (The two pin is a groundless flasher).
If you lay on your back on the drivers seat, with your head facing the brake pedal, slide down until your head hits the floor. Look up. Look right to your left on the steering column, the stock flasher should be on a bracket there.
RW
PS - If you go with load equalizers, you need to match about 2 amps, so you are looking at around 25W heat dissipation.
R_W is offline   Reply With Quote
Old 11-05-2005, 03:39 AM   #12
Dutch
Member#: 82272
led taillights piss me off. seriously whenever i see em in the dead of night i wanna have a seisure, they are so freaking hard 2 look at.
Dutch is offline   Reply With Quote
Old 11-05-2005, 11:08 PM   #13
jpsimon
Member#: 35570
2015 STi
sweeet. nice job! def wanna see a pic on the car with them lit up
jpsimon is offline   Reply With Quote
Old 11-08-2005, 04:03 PM   #14
idealrides
Member#: 10314
03 WRX 325hp SOLD!
the load resistors should arrive tomorrow... hopefully I should have time to put them in and get it done soon.
Old 11-10-2005, 04:54 PM   #15
idealrides
Member#: 10314
03 WRX 325hp SOLD!
finally all finished, load resistors installed, all connections soldered and sealed.
you can see that at certain angles the DOT reflector (the three horizontal stripes in the center of each brake light section, which are part of the taillight lens itself) visually interferes with the outer half of the LED pattern. A little disappointing but not too bad, kinda gives it a robotic look.
Anyway these pics are just the taillight... the brake light is much much brighter than stock, and the reverse lights are equally improved.
comparison to stock:
Old 11-10-2005, 04:56 PM   #16
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
bravo! nicely done.
Old 11-11-2005, 05:29 AM   #17
Power_Getter
Member#: 45089
2008 DGM STI -R Spec
2010 BMW X5 ///M
Very nice ! Very Good job
Power_Getter is offline   Reply With Quote
Old 11-11-2005, 05:31 PM   #18
mjd85la
Member#: 35176
1998 2.5 RS Impreza
2000 gray OBX
Very nicely done, love the origonality.
which read diffuser is that?
mjd85la is offline   Reply With Quote
Old 11-11-2005, 07:45 PM   #19
idealrides
Member#: 10314
03 WRX 325hp SOLD!
thanks. it's the OEM rear underspoiler, it comes prepainted and just bolts on.
Old 11-12-2005, 10:31 AM   #20
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
i like that "Stealth reverselight"
very clever.
however the tail light doesnt seem to have the same fill anymore.
but on the other hand, i'm sure the LED's are pretty intence
psyber_0ptix is offline   Reply With Quote
Old 11-14-2005, 05:54 PM   #21
idealrides
Member#: 10314
03 WRX 325hp SOLD!
very clever.
you're right, the fill is completely different and more intense. This was my intention, as I mounted the LED assembly flat against the taillight lens, which doesn't allow any light to escape and bounce against the reflector assembly. If you want to retain the "fill" of the factory light, just use a plug-and-play LED bulb!
Old 11-14-2005, 07:26 PM   #22
Handsdown
Member#: 29355
that's sweet. i would have left the outer 7443's functional as a brake light only, just for added "I'M BRAKING"-ness.
about 'plug-and-play' LED bulbs... the ones i've experienced are TERRIBLE in reflector/refractor housings. even the ones with side-facing led's don't look right. LED tails are much like HID heads... retrofit a dedicated unit in or don't do it at all.
Old 11-15-2005, 01:12 AM   #23
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
maybe if holes were cutout where the stock bulbs are mounted just barely large nough to epoxy the LED cluster into place, it will keep the LED's from the outer lens letting it fill a bit better (like wide output leds)
but thats just a thought, i'm sure clearences might be issues.
but excellent write up and very clever.
Old 11-15-2005, 01:31 AM   #24
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
not meant as a thread jack, but someone just passed this pic on to me.
make you wonder don't it
Old 11-15-2005, 01:38 AM   #25
GC8-40
Member#: 35650
2000 Impreza RS
RR,
I saw those at SEMA...pretty cool....but still hands down for custom job by idealrides!
John P.
Rally Innovations
GC8-40 is offline   Reply With Quote
FS $120 Black WRX Wing w/ led tailight -excellent condition -North Jersey Onedwn5up Exterior/Styling 0 02-19-2009 12:10 PM
Finished the HID retrofit for my06 Legacy Power_Getter Electrical & Lighting 4 09-06-2006 08:32 PM
Full LED Tailight Conversion Complete Basshead Electrical & Lighting 3 02-09-2004 09:13 PM
Just finished my blue LED conversion! Speedwagon Legacy Forum 15 05-09-2003 09:06 PM
Just finished my blue LED conversion! Speedwagon Mid Atlantic Impreza Club -- MAIC 12 05-09-2003 06:58 PM
