Old 12-17-2013, 10:23 PM   #26
kenlee
Member#: 49341
Bump, anyone able to resolve this issue?
kenlee is offline   Reply With Quote
Old 04-19-2014, 02:06 PM   #27
Evil Homer
Member#: 175522
Yearly bump for answers.
Evil Homer is offline   Reply With Quote
Old 06-04-2014, 10:41 PM   #28
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Yet another bump.
Swapped on my EJ207 injectors and turbo.
Jubert69 is offline   Reply With Quote
Old 06-21-2014, 11:51 PM   #29
Toadz
Member#: 262903
2003 WRX
Bumpity bump bump.
Just replaced heads and having this same issue. Crank with no start and these two codes come up together. Going to check out everything suggested so far..
Toadz is offline   Reply With Quote
Old 06-22-2014, 01:36 AM   #30
Toadz
Member#: 262903
2003 WRX
Cleaned MAF sensor and made sure no pins were bent. Checked main harness connections which were a little dirty so I hoped that was the issue but still no luck.
Old 06-22-2014, 01:58 AM   #31
Toadz
Member#: 262903
2003 WRX
By the way, it will fire and run if I pour fuel in through a vacuum line attached to the intake. Unplugging the MAF sensor and MAP sensor do nothing.
Old 09-01-2014, 03:12 PM   #32
pistonsmccoy
Member#: 351819
2004 STi
Had the same codes thrown today after tear down and inlet install. turns out i forgot to plug an injector in as well as both coil packs. plugged them in and it ran like a champ!
pistonsmccoy is offline   Reply With Quote
Old 09-04-2014, 05:29 PM   #33
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
check all yer grounds and the MAF plugs and get a voodoo priestess to perform a bad juju removal ritual
Old 10-04-2014, 08:28 PM   #34
Emv859
Member#: 403185
Default Same issue
Same issue... Any one on e85 with that issue or did any one find the cause of that devils code?
Emv859 is offline   Reply With Quote
Old 10-05-2014, 01:03 AM   #35
Emv859
Member#: 403185
Default I might have figured it out
I think I figured it out. Let me make sure that's what it is and I'll post updates with the fix
Old 10-10-2014, 10:50 AM   #36
Emv859
Member#: 403185
Default Issue fixed on my wrx
This is what I have done to fix this issue.
Put everything original u have replaced such as cold air intake was out on or something else. Replace ur maf and u should be in good shape.
Old 12-02-2014, 03:45 PM   #37
2002scoobybugeye
Member#: 221815
2002 2002 WRX Wagon
2000 Forester L
Default p0102
Bump anyone figure this out yet?
2002scoobybugeye is offline   Reply With Quote
Old 12-03-2014, 01:15 AM   #38
Uncle Scotty
Member#: 16200
OK buy Nates beans
https://www.google.ca/search?rls=com...p0102+wrx&btnG=
Old 01-18-2015, 04:08 AM   #39
Buburuu
Member#: 411183
2005 WRX WAGON
Turbo Silver
Default I MIGHT have some helpful information on this topic.
Just created this account to create this reply. I have been a long time lurker and recently when thru something similar to the original question, sort of.
My 05 Wrx Wagon was having low rpm problems when i would shift out of gear into neutral, dropping below the 500's often and rising when it reached almost the very bottom, yet it wouldn't stall. It had this issue for a few months until recently did it start stalling completely when going out of gear and taking one or two startups to get it going again as it would die immediately after i would start it, only had to do the starting issue when the car would stall and it didn't always require more then one start up. My car never threw any codes for this.
I received both of these codes when i unplugged my MAF while my car was running and it shut off. I figure this means the MAF is doing its job? After this i decided to remove the intake, and thoroughly clean the throttle body, idle air control valve (IACV), and air filter. My IACV was filthy and gunky and i CAREFULLY cleaned it with throttle body cleaner and q-tips following a write-up i read here.
I apologize if some of this is not relevant but it may help someone in more than one way. Basically i believe anything with those codes will be related to a air problem. I read if you unplug it and the car keeps running that means its bad, but I'm not sure if its legible or not. Only other options would be a multimeter test, or connecting an OBD2 and creating a graph with the car running and i believe there is people in this forum that can see it and tell if its going bad. (EDIT) By the way in doing this all my issues went away and the car idles much nicely now, it always goes to the 1k rpm mark and slowly drops to the 500s.
I can post links to things relating to my issues if anyone needs them but again none of these relate directly to the problem the OP posted but i made them come up and feel this might help someone! Message me for any questions relating to issue and i might be able to help out i have learned quite a bit a long the way.
Buburuu is offline   Reply With Quote
Old 08-20-2015, 02:03 PM   #40
tucker1170
Member#: 379589
Sunburnt Copper
In my infinite stupidity, I learned that I had installed the MAF backwards which is what was causing my P0102 and P0113 codes. It was easily done with a home built CAI. Glad I figured it out but UGH!
tucker1170 is offline   Reply With Quote
Old 12-15-2015, 06:41 PM   #41
spaceboy05
Member#: 264446
06 wrx
Aspen white
Did this help anyone else out? I am throwing p0112 and p0102 myself and car wont start either. Someone find the solution to this problem!!!
spaceboy05 is offline   Reply With Quote
Old 12-18-2015, 04:27 PM   #42
spaceboy05
Member#: 264446
06 wrx
Aspen white
bump? I need a running wrx
Old 01-28-2016, 08:50 AM   #43
nomorepoison
Member#: 193528
1997 V8 Tomei Swap
Coat of many colors
Im gonna go ahead and bump this as well. Im getting both codes, as well as a P0037 P0112. Car runs and drives pretty well actually, makes boost just fine, and even idles fine when its warm. Has some delay in throttle though. However on startup, it idles kinda rough, and sounds like its backfiring a bit through the intake. These symptoms all go away as soon as I touch the throttle though, and it idles fine.
nomorepoison is offline   Reply With Quote
Old 01-31-2016, 09:01 AM   #44
nomorepoison
Member#: 193528
1997 V8 Tomei Swap
Coat of many colors
Went out and checked voltage on my maf connector. My wire colors are different for some reason, so these are listed from left to right, looking at the connector. What I get is the following
Key in on position, engine not on
YL---12v
BG---Ground
G----0v
LW---4.75
BR---Ground
Engine on
YL---12v
BG--Ground
G----1.62v
LW---3.95
BR---G
Really want this issue fixed, have a dyno day this friday...
EDIT: To make matters weirder, turned the car on, warmed it up, and erased the codes. now both these codes are gone... only have P0037, which I had before.
Old 02-01-2016, 09:45 AM   #45
nomorepoison
Member#: 193528
1997 V8 Tomei Swap
Coat of many colors
Drove to and from work last night, no codes today... So weird
Need help with CEL codes 170 and 141 Rich L Normally Aspirated with bolt-on Forced Induction Powertrain 4 12-02-2008 07:16 PM
P0113 and P0102 after MAF clean speedin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-28-2008 10:05 PM
swapped to modified deatschwerk injectors - now CEL codes p0103 and p0113? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-23-2006 03:07 PM
Cel codes p0122 and p0442 turbocolin Tri-State Area Forum 3 03-22-2005 08:00 PM
Causes of CEL codes P0122 and P1133 nytoy Normally Aspirated Powertrain 5 12-27-2004 01:12 PM
