Old 11-02-2005, 11:00 PM   #1
dan0025
Member#: 68492
08 WRX Hatch Back
89 BMW 325i track car
Question stock shocks with Eibach Pro Kit springs?? 04 WRX Yay, Nay?
Anyone had any experience with the stock struts with the Pro Kit springs? Ride quallity over bumps at low speeds with stock struts vs. Koni, Ohlin, STI, KYB GR2s.....other options? I'm not having the easiest time reseaching what my best combo will be.
If the ride is decent and the springs won't tax the stock struts too badly I'de rather save the money. On the other hand I only want to do this once for at least the next few years so I don't want to regret not going with another option if it is really that much better.
Please give me your insight as I'm sure a lot of you have much more experience than I do. I want a comfortable every day ride with reduced body roll enhanced looks. I already have a White Line rear sway bar installed.
Thank you so much in advance for the advise
Dan P
dan0025 is offline   Reply With Quote
Old 11-03-2005, 11:26 AM   #2
FromageTheDog
Member#: 81095
2005 WRX sedan baby-
bus. OS self-tuned!
I certainly don't have more experience than you do, but this guy probably does:
http://www.spdusa.com/chassis.htm
http://www.spdusa.com/new_page_9.htm
And his relevant comment about the Eibachs:
"The Eibach Pro-Kit and Prodrive spring kits are designed to run on the stock struts and will lower the car about 30mm. The Prodrive is a more neutral handling car, while the Eibach have a softer ride quality. Your choice, either way is good with the stock shocks."
- Fromage
FromageTheDog is offline   Reply With Quote
FS/FT: (PA) WRX Stock Struts with Eibach Pro-kit Springs shissqbob Suspension/Brakes/Handling 8 05-07-2010 10:04 AM
KONI sport (yellow)/KYB/Tokico D-SPEC adjustable shocks w/Eibach Pro-kit springs GDAryder Brakes, Steering & Suspension 8 10-30-2009 02:02 PM
FS: Eibach Pro Kit Springs 04-07 WRX Uncle Tattoo MAIC Private Classifieds 9 05-21-2008 05:00 PM
WRX Eibach Pro-kit Springs 04+ jeebusm3 Suspension/Brakes/Handling 6 09-22-2006 03:26 PM
Best Shocks for Eibach Pro-Kit on 04 WRX Sedan? shebal Brakes, Steering & Suspension 15 07-28-2005 07:25 PM
Message Board Statistics All times are GMT -4. The time now is 10:46 PM.
