Old 11-03-2005, 01:18 AM   #1
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
Default CEL codes P0102 and P0103 both
I dunno what is up the car is not in limp mode. but im firing both cel's p0102 maf circuit input low and p0103 maf circuit input high. what gives?
NITROS is offline   Reply With Quote
Old 11-03-2005, 01:43 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
Boost leak most likely. Check for leaks between the MAF and throttle body.
Calvin
cnk is offline   Reply With Quote
Old 11-03-2005, 07:11 AM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
It's unusual to find both of those logged together. A possible cause could be a broken wire that occasionally touches ground.
Jon [in CT] is offline   Reply With Quote
Old 11-03-2005, 11:41 AM   #4
modaddict
Member#: 95840
sold to a good bud
awaiting next car
check your maf sensor connection and make sure the connector is seated all the way....unplug it and plug it back in. ive seen these codes a handfull of times on "partially seated" maf connectors.
modaddict is offline   Reply With Quote
Old 11-03-2005, 03:53 PM   #5
NITROS
Member#: 41561
04 GT3076 2.1
I will try this when i get outta work. Another wierd note is when i got in the car this morning the cel was off, i did not clear the codes or anything.
-Walter
Old 11-03-2005, 04:37 PM   #6
modaddict
Member#: 95840
sold to a good bud
awaiting next car
probably because the maf circuit made a good contact again and now theres no problem.
Old 11-15-2005, 06:13 PM   #7
MadDogSTi
Member#: 85428
2006 Enzo Ferrari
damn...my car just threw a CEL today. P0103, it was raining out(light shower) and after my lil bro i took off and came to a stop at a stop sign. suddenly my car struggled for air and then the CEL came on...and yes it's limping now if i floor it. but now the CEL is off when i parked the car for a good 10-15mins.
i've been out when it's raining cats and dogs and my car is fine, even if i park it outside when it's raining cats and dogs (i'm also missing the weather plates). till now it threw another CEL
MadDogSTi is offline   Reply With Quote
CEL code P0113 and P0102 together kingtut12 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 02-01-2016 09:45 AM
Need help with CEL codes 170 and 141 Rich L Normally Aspirated with bolt-on Forced Induction Powertrain 4 12-02-2008 07:16 PM
UTEC 5.0 and CEL code P0102 AURAz UTEC 16 08-18-2006 01:55 PM
Cel codes p0122 and p0442 turbocolin Tri-State Area Forum 3 03-22-2005 08:00 PM
Causes of CEL codes P0122 and P1133 nytoy Normally Aspirated Powertrain 5 12-27-2004 01:12 PM
