Welcome to the North American Subaru Impreza Owners Club Saturday January 31, 2015
Old 09-05-2012, 08:18 PM   #4651
Indocti Discant
Member#: 138000
L Bo Hope you meet
the spirit in the sky
i am no espresso expert but that looks like a machine problem to me.
is it completely clean?
Indocti Discant is offline   Reply With Quote
Old 09-05-2012, 09:32 PM   #4652
poison
Member#: 37678
Whoa. What's your grind/tamp procedure? walk me through the steps.
Also, are you using a new bean, or did you roast differently?
poison is online now   Reply With Quote
Old 09-05-2012, 11:48 PM   #4653
Pallendo
Member#: 65831
91 Miata. Hey you
can f* short girls in one
Well, this is with 3-6 day beans (After roasting), same beans as I was using in Ohio, roughly the same roast levels (city+ to full city, hard to hit exactly what I want with an air-roaster) Same grind size...
I weigh out 15g of beans, and toss them in the hopper of my MD-50, grind out and dispense into the basket. Then I tap the filter on the counter to sorta re-distribute the grounds, then tamp as best I can to ~30lbs and then spin the tamper to "polish". then I run a "cooling shot" to force the head to boiler temp (Tends to run hot), then I mount the porta filter and pull the shots. I am getting ~25-35 seconds to 2oz, so I thought I was good, but for the past week, I have been getting that odd channeling. I have not run any sort of de-calcification as I did that about 4 weeks ago, but I might have to do it again, but I was not getting any of this channeling before the last time I did this.
every drop of water I have put into this machine is through a britta pitcher, as my old house had a water softener and this new place the water smells a bit chlorinated.
If you tell me to de-calcify again, I will do it, but just wanted an opinion.
Pallendo is offline   Reply With Quote
Old 09-06-2012, 12:08 AM   #4654
poison
Member#: 37678
It's generally a distribution issue. Do the grounds clump out of your grinder? If they are clumped when you tamp, you'll get nasty channelling. A difference in humidity and temp from the move could require a different distribution technique.
I generally updose the PF so it's highly mounded. I perform a modified Stockfleths circular sweep, then sweep the mound off NSEW, tamp, pull shot.
http://www.fivesenses.com.au/blog/20...r-distribution
As far as water, buy some Fiji just to see how it changes the taste, and modify your water supply from there.
Old 09-06-2012, 12:11 AM   #4655
SpeedsterX
Member#: 320776
2012 WRX
This thread is giving me the itch...FOR COFFEE!!!
SpeedsterX is offline   Reply With Quote
Old 09-06-2012, 12:40 AM   #4656
poison
Member#: 37678
Scratch it.
Old 09-06-2012, 04:49 PM   #4657
poison
Member#: 37678
How's it going, pallendo?
Old 09-06-2012, 04:56 PM   #4658
Pallendo
Member#: 65831
91 Miata. Hey you
Well, I made a trip out to lowes for some plexiglas so I can make a tool. I am all about accessories. I will be trying it out later...
Old 09-06-2012, 05:08 PM   #4659
poison
Member#: 37678
Tool for...?
Old 09-06-2012, 05:23 PM   #4660
Pallendo
Member#: 65831
91 Miata. Hey you
Tool for...?
For redistributing the grounds in the pf basket.
Old 09-06-2012, 05:40 PM   #4661
poison
Member#: 37678
The chop-chop method? Another way is to simply take a toothpick and stir the grounds in the pf. I would go crazy after 2 shots of doing that, and stab myself in the eye.
Old 09-06-2012, 06:02 PM   #4662
Pallendo
Member#: 65831
91 Miata. Hey you
I did the toothpick method this morning and got exactly the same channeling as yesterday, and the week leading up to yesterday...
Old 09-06-2012, 06:04 PM   #4663
poison
Member#: 37678
Weird. I'd say maybe pump pressure is too high, but you said the extraction time is ok.
Old 09-06-2012, 06:28 PM   #4664
Pallendo
Member#: 65831
91 Miata. Hey you
Too fine of a grind + too high of pump pressure = normal extraction time + channeling?
Old 09-11-2012, 09:48 PM   #4665
poison
Member#: 37678
A new Colombia inbound, from an award winning farm.
Old 09-19-2012, 03:48 PM   #4666
poison
Member#: 37678
Colombia is up!
Old 09-19-2012, 07:44 PM   #4667
poison
Member#: 37678
Here's some info on this coffee:
THE CUP
Yellow Bourbon microlot. Heavy bodied and fruity with a tart cherry acidity and distinct cocoa after taste; GRAINPRO BAGS.
ADDITIONAL NOTES
Average temperatures: 18-23 degrees Celsius
Average precipitation: 2000-2400 mm
Total trees of this variety: 9,600
Total area of this variety: 2.4 ha
This is one of the most progressive and quality focused farms around the world. The view of the farm is impressive. It looks like a perfect variety garden.
This is one of a few different experimental single variety projects at Granja La Esperanza. Everything at this farm is focused towards quality improvement. Data for every imaginable detail is logged in order to find correlations between different variables and positive results.
The warehouse were coffee is stored is temperature and humidity controlled.
Each new variety projects takes about 10 years to be in full production. The first five years are only to determine if the project is viable (only a few acres are planted). The next five years is what it takes for the variety to be in full production.
Varieties are bred selectively to produce only pure offspring.
Find Similar Products by Category
These guys have grown some ridiculously good coffees; their Esmerelda goes for $100/lb. I can't wait to dig in and find its sweet spot.
Old 09-19-2012, 08:13 PM   #4668
Tecolote
Member#: 264381
2002 WRXWGN | SLVR
I just got some Folgers Colombian for the coffee maker. Ah yeeeaah.
Tecolote is offline   Reply With Quote
Old 09-19-2012, 08:30 PM   #4669
poison
Member#: 37678
When a potential customer derps it up and buys Folgers. #Muslim Rage
http://storify.com/danielsburke/muslim-rage
Old 09-19-2012, 08:33 PM   #4670
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
0/10 troll harder
XanRules is offline   Reply With Quote
Old 09-19-2012, 10:32 PM   #4671
poison
Member#: 37678
Originally Posted by XanRules View Post
0/10 troll harder
Exactly.
Old 09-20-2012, 12:20 AM   #4672
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
the gourmet supreme is far better....the black silk is ok, but has no BITE
and Nate....I'mma gonna order sum coffee tonite or tomorrow for my vacation....what ya got GOOD for uncle???
i think 2 pounds would do it
Old 09-20-2012, 11:02 AM   #4673
poison
Member#: 37678
Folgers discussion in my teh coffee thread?
Old 09-20-2012, 01:22 PM   #4674
tegan_ca
Member#: 150388
'14 FXT
Originally Posted by Indocti Discant View Post
which is true, but I was comping it to the regular brewed coffee, so relatively speaking.
As for the grind, I was told you could go better, if you were happy with the machine breaking down every other month. As it stood it was a once a year maintenance. I fuxored it up my first month when I tampered with the grind setting..
I think my point was more to the effect of more commercial is better if you are doing the 50 cups a day.
BUT then again I think I was the only person in the office who thought the Saeco average. Everyone else loved it.
Update: Kcup maker will be purchased for office
Bought aeropress for myself yesterday, tired of cleaning the french press. Awesome coffee
tegan_ca is offline   Reply With Quote
Old 09-20-2012, 01:26 PM   #4675
poison
Member#: 37678
Ugh, damn. That sucks man. Well, at least you can fend for yourself with your aeropress!
The Master McD's Monopoly game piece thread! BacDoc Off-Topic 253 10-03-2014 12:29 PM
Photochop Classics: The Master Thread DrDRum Off-Topic 120 02-22-2009 02:58 AM
"I smell coffee, do you smell coffee? Who's got coffee?" gongzero Off-Topic 83 06-23-2006 01:40 PM
Official Master OT Thread For Things Mitsubishi Says They're Doing rogue Off-Topic 3 11-02-2005 11:20 AM
Brucelee the Master Crossposter- 7 threads WRSport Bay Area Impreza Club Forum -- BAIC 7 05-13-2002 01:02 AM
