Old 11-03-2005, 08:56 AM   #1
TexRex2002
Member#: 36303
06 Evo IX
Default UTEC last knock event
is there any way to know how big of a knock event it was?
does the "knock correction" give it away (ie if it is 16, it was bad, if it is 2.5 not so bad?)
I get this in my dashboard every now and again, but am pretty sure it's just my noisy pistons. I have my threshold set to 2 and the CEL doesn't blink unless it is a 2 or bigger.
I really wonder though if I am just missing a big knock event, or if it is just the little CP piston 1 count... (I am leaning strongly to the latter, since i am only running about 10 psi, rich, and 16 - 18 degrees of timing).
TexRex2002 is offline   Reply With Quote
Old 11-03-2005, 11:24 AM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
If you set your sensitivity to 2 you aren't missing a large knock event, only a 1 count. You can measure how many events you missed with your settings for timing pull, count, duration ect. I wish it kept a whole log line not just the 3 parameters.
cdvma is offline   Reply With Quote
Old 11-03-2005, 11:34 AM   #3
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Three parameters in the UTEC...
Timing retard step - ammount to pull on each knock event past threshold
Timing max retard - max ammount to pull as a sum of events for the above event
Timing knock window time - how long before it will make another adjustment (minutes)
So say you have default values: .5, 5, 5 respectively. If you check your dashboard and it lists knock correction as 2 degrees you know that you had 4 seperate knock events that were at least 5 minutes apart from eachother but possibly more that occured within 5 minutes of eachother. You also know they were a severity of 2 or more. If you have 5* correction you know that you had at a minimum of 10 "groups" each 5 minutes from eachother.
Edit: *(@#*E(@##(*&@(#*$# NASIOC is so messed up with the out of order posts. This is in response to the question "expand..."
Old 11-03-2005, 11:37 AM   #4
TexRex2002
Member#: 36303
06 Evo IX
ooh, can you expand on this a little?
I am having a hard time visualizing. The Benadryl isn't helping either...
Old 11-03-2005, 11:53 AM   #5
TexRex2002
Member#: 36303
06 Evo IX
ok I am beginning to understand.
how about the parameter for CEL Knock Threshold. I have it set for 2 as well as the Knock Count Threshold (4 parameters up).
my CEL NEVER flashed during a pull, but I still get the knock event data in my UTEC Dashboard. that is what made me think it is one-counts.
Are you sure it takes more than your threshold for it to be captured in Dashboard? (ie more than 2 in my case???).
Thanks!
Old 11-03-2005, 12:50 PM   #6
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
The dashboard will capture the last knock event even if it doesn't pull timing or flash the CEL.
Old 11-03-2005, 03:11 PM   #7
TexRex2002
Member#: 36303
06 Evo IX
right. and there is danger here!
I went out and did some spirited driving, and due to noisy pistons get 01 counts all over the place.
The UTEC pulls the timing in .5 degree incremements to -5, even tough the CEL is not flashing, and the 01 counts are below my threshold.
Well, now I'm in a long 4 th gear pull, and only running 10 or 11 degrees of timing, causing my EGT's to shoot towards 850-900 OMFG!!! and I'm only running 12 psi (wastegate boost).
so while I was getting gas I turned the timing retard step to 0. I do not need warped heads!!!
Anyway, glad I figured that out...
Will utec log knock events in log when not in control? MAP 0 NITROS UTEC 1 08-21-2007 10:55 AM
STI V7 Knock Event stimpy Engine Management & Tuning 11 05-10-2005 07:14 PM
my first utec log. knock knock, who's there Rickyh Engine Management & Tuning 4 10-13-2004 06:14 PM
Weird Knock Events ShaggyGT Engine Management & Tuning 29 01-22-2004 06:28 PM
Recent knock events Silver '02 REX Engine Management & Tuning 8 06-19-2003 02:08 PM
