Old 11-03-2005, 02:02 PM   #1
rainbow123
Member#: 99854
Default whining noise and overheating, help please!
I have a 93 subaru impreza with 120,000 miles, was driving on a stretch of highway yesterday and suddeningly i heard a continous high-pitched whining noise, i kept driving for 1 mile or so, then temp needle rised very quickly from midline to top in about 10 seconds, i immediately pulled over and shut down the engine. After a bit cooldown, i took off radiator cap and see full level of coolant. I restarted and the car idles with temp needle in mid-line. But if i rev it to maybe 2000 RPM for 40 seconds, the needle would rapidly rise again. All the while there is that continous whining from the engine.
The belt seems to be tight, there is no leak and all the coolant is still there. There is no prior warning before this sudden onset of whining noise. Is my water pump shot? any body has experience with this whining noise typical of this water pump not working? but why is that when i idle the temp is ok and only overheats when i rev it up?
thanks for your help guys
rainbow123 is offline   Reply With Quote
Old 11-04-2005, 10:05 PM   #2
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default water pump whine
Sounds like you're on the right track. I'd say its your water pump bearings. You'll have to remove the timing belt to swap it out.
Is the whining coming from the front driver's side of the engine?
-Charles-
ImprezaVA is offline   Reply With Quote
Old 11-07-2005, 04:16 PM   #3
LoveRoadRacing
Member#: 80500
2002 2.5L WRX
Blaze Yellow
He's right. Money's on the water pump.
LoveRoadRacing is offline   Reply With Quote
Old 11-07-2005, 08:35 PM   #4
Hayes
Member#: 11808
Get it checked ASAP because if the waterpump locks up it can take the timing belt out and that's is many dollars to fix the engine.
Hayes is offline   Reply With Quote
Pulsating exhaust noise and stuttering..HELP! horrorbiz Normally Aspirated Powertrain 10 07-24-2006 09:17 PM
weird clunking noise up front help please manimal15611 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-05-2005 11:29 PM
Spring and RSway help please!! Crash477 Brakes, Steering & Suspension 5 06-19-2004 04:40 PM
connecting 3 gauges and need help please mustangsmoker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 11-24-2003 06:54 PM
BOV causing noise in Trubo..Help Please JenisonWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-14-2001 09:00 PM
