Old 11-03-2005, 02:43 PM   #1
glh37
Member#: 99367
Default code P1507 input please
i went to auto zone and pulled the code P1507 Idle Control System Malfunction (Fail Safe). anyone know the problem and solution.
thanks in advance
glh37 is offline   Reply With Quote
Old 11-04-2005, 02:15 PM   #2
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
Knowing what vehicle, engine, year, and type of transmission you have would be most useful.
SubyTechMaster is offline   Reply With Quote
Old 11-04-2005, 04:14 PM   #3
glh37
Member#: 99367
i have an 02 impreza rs with a manual trans.
Old 11-04-2005, 07:12 PM   #4
NRTmotorsports
Member#: 16517
'13 BRZ
Could be a dirty Idle Air Control Valve, is you car running ok? Any surging at idle? I had this problem om my WRX and it turned out their was a piece of carbon stuck inside. I cleaned it out and it idled much smother. Read the write at the top of the page on how to remove and clean your idle air control valve. I'm pretty sure an RS and WRX have the same type?, but I could be wrong. Good Luck
NRTmotorsports is offline   Reply With Quote
Old 11-04-2005, 08:10 PM   #5
glh37
Member#: 99367
hey thanks alot, you could be right because my car does run smoothly so i will take you up on your advice.
CEL code P1507 with no symptoms dlong27 Normally Aspirated Powertrain 2 11-05-2008 10:27 PM
CEL codes P1507 and P507 speedyHAM Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-10-2007 08:20 AM
Q's on this code P1507 Nok's WRX Tri-State Area Forum 5 01-10-2005 09:06 PM
3 Codes....Input please SloRice Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 04-29-2004 10:03 AM
your input please! wrx for sale! need advice! fooie8 General Community 6 12-29-2001 05:10 PM
