Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 11-03-2005, 04:39 PM   #1
Member#: 94053
2004 wrx
Default dash pod wiring
i have a 04 wrx, i just bought defi d guage oil press, egt, and a/f. my question is can i take the harness that plugs into the back of the clock and wire my guages in to that plug. ground,12v,illumination,and ignition. or what are some of the other ways you guys have done this.
cyacop is offline   Reply With Quote
Old 11-03-2005, 06:14 PM   #2
Member#: 37617
Yes you can.
WR^2X is offline   Reply With Quote
Old 11-08-2005, 10:15 PM   #3
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
For a A/F Ratio gauge (and for the other 2 as well, when you already have the wires there) isnt it best to run the 12v and ground wires directly to the battery, in order to get a good clean ground.
I had my gauges (oil temp, oil pressure and boost) connected to the wiring harness/adapter between the stock wiring and the radio
and always had a problem with the gauges dimming a bit when playing songs with some deep bass in it.
I could live with that.
I then purchased a Omori A/F gauge, which didnt seem to work as it was supposed to (readings different with radio on/off , heater on/off and such)
Returned the unit, got sent another which had exectly the same problems.
Got pissed off, and after some research decided to run dedicated wiring (ground, 12v) to the radio, 3 gauge pod in the dash housing and the pillar pod mounted AFR gauge, only using illumination/switched wire from the adapter behind the radio.
1 No more dimming of radio/gauges
2 AF ratio that works like its supposed to.
The original A/F sensor wire at the ECU and in the exhaustsensor only sends out a voltage between 0,5 and 1 volts, with stoich. mixture somewhere between 0,87 and 0,9 volts of output, so having a bad earth will render the (already not very usefull) output of the original narrowband sensor useless.
So i would encourage u to run some wiring inside the cab from the battery (fused at the batt, of course) to power your gauges.
Dutch Scooby lover is offline   Reply With Quote
Autometer Triple Dash Pod - anyone has picture of installed pod? txl146 Electrical & Lighting 6 08-04-2009 10:05 PM
Wiring ? for dash-pod screen AUTOFX Car Audio, Video & Security 4 08-30-2007 08:56 PM
wtb. 52mm 3 gauge pod dash pod for 2001 rs ej25turboRS Private 'Wanted' Classifieds 4 05-18-2006 09:24 PM
queston on wiring up dash pod cyacop Electrical & Lighting 3 12-20-2005 07:33 PM
wiring a dash pod on 04 wrx cyacop Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-03-2005 04:36 PM
