Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 08-31-2001, 02:01 PM   #1
VOLTIS5
Member#: 2353
98' LegOver GT
dark whiteish pearly red
Question how to drift with a GT?
ok, so it was raining hard last night and i thought i'd be kinda cool to try a little drifting(fake), but the only thing is i cant do it . how the hell do peolpe do this crazy stunts. i've seen em done and read about em but for some reason it looks easier said than done. any addvice would help (yeah i know i suck, gotta learn sometime)
VOLTIS5 is offline   Reply With Quote
Old 08-31-2001, 02:14 PM   #2
nitrohuffer
Member#: 6982
2001 Legover
04 forester xt
Adjusting your air pressure will help get the tail loose, if thats what you want. Run around 40psi up front and 30 in the rear. That should help get you nice and sloppy. You just need to learn how your car reacts. Go to a big parking lot and play around(off hours of course!) Don't use the e-brake!
nitrohuffer is offline   Reply With Quote
Old 08-31-2001, 02:39 PM   #3
VOLTIS5
Member#: 2353
98' LegOver GT
oh "not using the e-barkes" might have help , welp i hope it rains agian
Old 08-31-2001, 04:15 PM   #4
euroauto
Member#: 249
05 FXT psm
12 R350
wait until it snows!
euroauto is offline   Reply With Quote
Old 08-31-2001, 05:30 PM   #5
Narcisse91
Member#: 3931
WRX, Ninja, RX-7
Legacy, Fiat 850
The best way to drift without any preperation (brake adjustment, tires, etc) is a quick tug on the e-brake. You can do it on dry pavement going 30mph if your timing gets good enough. The important thing is to use the e-brake to start the slide, then take the brake off (don't even let go of the button, hold it in... pull the brake up, and put it down almost right away) and give it a lot of gas.
Narcisse91 is offline   Reply With Quote
Old 08-31-2001, 11:21 PM   #6
nitrohuffer
Member#: 6982
2001 Legover
04 forester xt
Yanking the e-brake will f-up your center dif. if I'm not mistaken. I did it once and the mighty clunk below did not sound good! But yeah, that will get you around in a hurry!
Old 09-01-2001, 12:28 AM   #7
JoeT
Member#: 3956
2000 Turbo Legacy GT
Titanium
Take a look at the video from the AutoX in my previous post. That was done doing a variation of the "Scandanavian Flick".
1) With the tires I was using (BFG G-Force KD), the pressures were set at 50 psi front, and 40 psi rear. The tire pressures will vary with the type of tires you use.
2) Accelerate in a straight line up to 35 mph
3) Push full throttle and turn your wheel 90 degrees to the left, just enough to compress the RHS suspension
4) Reduce throttle input (0 throttle) (weight transfer) and gradually turn your wheel 90 degrees to the right.
5) The car will enter a drift forcing the tail of the car outwards (left) modulate your throttle lightly to keep the drift going or push hard on the throttle to power out.
Practice makes perfect...
Enjoy
Note: Do this only in a closed / controlled environment supervised by professional instructors, if you are doing this for the first time. Do not do this on the open road, please!!!!
JoeT is offline   Reply With Quote
Old 09-01-2001, 04:49 AM   #8
VOLTIS5
Member#: 2353
98' LegOver GT
dont worry, i tried this in the back parking lot of my work place. thanks for the info guys
LET THE FUN BEGIN
Old 09-01-2001, 10:56 AM   #9
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
1. Flick wheel left (for a right hand drift)
2. Hit gas, turn wheel right
3. Have fun drifting
4. Buy new tires.
remarcable is offline   Reply With Quote
Old 09-01-2001, 01:31 PM   #10
RandyF
Guest
Member#:
http://plastik.pnwsec.org/GTScoob/GTscoobnut.wmv
(might have to right-click-save)
My process:
#1 - Come into corner, start turn
#2 - clutch in e-brake until you feel the back end break
#3 - clutch-out HARD on gas (keep the wheels straight... AWD drifts do not take place with opposite-lock)
#4 - (here is where you guys will hate me) If the car starts to hook up during the drift, pop the e-break quickly while still on the gas. YES, this warms up the center diff a bit, but keeps ya pointed in the right direction!
E-brake will only "hurt" the center diff when the power is down, if you clutch it when you handbrake you take the stress off of the center...
A
How to drift a Subaru awddrifter Off-Topic 40 12-17-2005 04:18 PM
How to drift a GC8... Wired Magazine Bobalouy General Community 0 09-12-2003 05:49 PM
learn how to drift drift king North West Impreza Club Forum -- NWIC 7 12-15-2002 10:25 AM
OT: how to drift. vsigma Tri-State Area Forum 12 10-17-2002 04:25 PM
How to drift? SubieFL Technical Forum Archive 11 08-04-2000 11:36 PM
