Old 11-04-2005, 06:20 PM   #1
six1five
Member#: 50177
2000 Impreza 2.5 RS
Silverthorne Metallic
Question ABS light still on after ABS ring replacement
i'm not sure if there's still a problem with the abs. i tried a couple hard stops and had no problems.
do i need to reset the computer? if so, how do i go about doing that?
thanks in advance, for any help.
six1five is offline   Reply With Quote
Old 11-04-2005, 07:41 PM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Did you replace a tone ring that was damaged or something? Are you sure the sensor didn't get whacked, too?
To reset the computer, I imagine you do the same deal as for the main ecu - pull the negative battery cable and pump the brakes (with the car off)
Old 11-08-2005, 01:33 AM   #3
six1five
Member#: 50177
2000 Impreza 2.5 RS
bump..
Old 11-08-2005, 10:29 AM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
take it to a dealer/mechanic
all we can do is randomly guess what the issue is.
brake pads low? low fluid?
if you've tried all that, it's probably time to let a pro take a look at it.
Jamie
airbag light...still on after putting in a different clock spring fusionchicken Service & Maintenance 14 08-23-2010 07:17 PM
ABS light in the dash...Tone ring prob. TaurusMcRae007 Service & Maintenance 3 05-24-2009 04:17 PM
anyone have airbag and ABS light come up after swap? simprezl25 Subaru Conversions 26 04-13-2009 10:19 PM
Ebrake light is still on after ebrake is release. ultraspdWRX Brakes, Steering & Suspension 4 04-13-2009 05:17 PM
HELP! DCCD light flashing and ABS light is ON. Diff in FULL LOCK. 04 STi. ProdriveRex Transmission (AT/MT) & Driveline 12 02-28-2007 11:03 AM
