Old 11-04-2005, 07:41 PM   #1
TRinityMtrSprts
Member#: 43720
2002 mbp WRX
97 Ford Ranger on Bags
Question liquid or air in the rear view mirror??? ::pix::
well i got in my car 2 days ago and drove to class in the morning and noticed that my rear view mirror had what looked to be an air pocket inside of it... i thought it was dirty at first, but when nothing happened when i tried to wipe it clean i figured maybe some moisture got in between the glass and mirror some how.... is there any way to fix this it shifts like an air bubble when you move the mirror
ERic
02 WRX Sedan
TRinityMtrSprts is offline   Reply With Quote
Old 11-04-2005, 07:46 PM   #2
2006STI
Member#: 96540
2006 STI
Crystal Metallic
its something in the auto dimming mirror thats gone bad. you will need a new mirror which cost a like $300-$400. no fix for it. seen a few of those mirror in that condition at my work on older cars.
2006STI is offline   Reply With Quote
Old 11-04-2005, 07:59 PM   #3
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Yup - common failure of the electrochromic mirrors.
mcowger is offline   Reply With Quote
Old 11-04-2005, 07:59 PM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
the older Donnelly mirrors (pre-2003 or so - mostly the ones with green lighting, rather than blue) used a liquid material between the two layers of glass to provide the autodimming feature - newer ones use a solid material. Looks like yours failed - you will need to replace it. You can usually get them on eBay or online brand new with all the bells and whistles (compass, outside temp, maplights) for under $200 brand spankin' new. (that's how I got mine - I replaced my original dimming mirror because I wanted outside temp) just make sure you get a mirror with a cam-lock mount (that's what Subaru's use) and you will be all set. The newer ones turn sort of greenish as they autodim, vs. the older ones which turn grey.
Here's one on eBay now
http://cgi.ebay.com/ebaymotors/FREE-...spagenameZWDVW
Old 11-04-2005, 08:11 PM   #5
TRinityMtrSprts
Member#: 43720
2002 mbp WRX
awww crap .... well that sux.... thanks for the link man.... i'd buy it if i wasn't broke right now
are these on ebay a lot???
for future refference
Old 11-04-2005, 09:17 PM   #6
SubasaurusWrex
Member#: 70285
2011 JCW Mini
Midnight Black/Red roof
nice rebel(?)
SubasaurusWrex is offline   Reply With Quote
Old 11-04-2005, 09:21 PM   #7
atom945
Member#: 75969
will anything happen if he happens to leave it how it is? mine has been like that for 2 months and i have gotten use to it
atom945 is offline   Reply With Quote
Old 11-04-2005, 11:35 PM   #8
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
there are almost always one or two of them available - there are also online vendors who sell them for just a little more.
Old 11-05-2005, 12:03 AM   #9
ESEMES
Member#: 67128
2001 996TT
seal
no worries....
i have a takeoff unit (about one week old; no blotches/waves) ----(same exact model as yours) from my 06.
pm me if you want it.
ese
ESEMES is offline   Reply With Quote
Old 11-06-2005, 05:26 PM   #10
andygold
Member#: 7347
2002 Impreza WRX
WR Blue
atom945....the bubble will get bigger and bigger until the darker color within the mirror is totally gone. Problem is, with the liquid gone you don't get a clean view from that mirror. You get a hazy view day and night. I don't know where the liquid goes, it doesn't drip out anywhere. I guess it just evaporates.
andygold is offline   Reply With Quote
Old 11-06-2005, 06:04 PM   #11
pankopp
Member#: 29552
2005 Forester XT
yep i have the same problem, its been like that ever since thoes 100 degree summer days, it all evaportated i quess. no worth paying more than a hundred dollars
pankopp is offline   Reply With Quote
Old 11-07-2005, 07:21 AM   #12
andygold
Member#: 7347
2002 Impreza WRX
WR Blue
I wonder if their newer solid film mirrors will last/work better than the liquid ones?
Old 11-28-2005, 02:28 PM   #13
VT_453
Member#: 30396
2003 WRX
how hard are these to install if you are replacing a factory one thats evaporated?
VT_453 is offline   Reply With Quote
Old 11-28-2005, 02:37 PM   #14
shemoves
Member#: 80663
2005 STi
any chance the car is still under warranty?
shemoves is offline   Reply With Quote
Old 11-28-2005, 08:16 PM   #15
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
trivial - unplug the mirror, twist it 90 degrees and slide it off the mounting button. Check the spring to make sure it isn't bent (otherwise the new mirror will rattle) make and adjustments to it which you have to (i.e., bend it back) slide the new mirror on the button (90 degrees off of the correct position) then twist it 90 degrees so that it's held in place. plug it in and you are done - should take a couple of minutes, total.
Old 11-28-2005, 09:57 PM   #16
VT_453
Member#: 30396
2003 WRX
Nice, glad it uses the same plug, didnt know if that would be a problem or not
Thanks
Old 11-28-2005, 11:40 PM   #17
nimblegimbal
Member#: 91120
06 WRX ImpWag
Batmobile Black
actually, iirc, vendors sell them cheaper than that...
like.. $130 at https://www.subarugenuineparts.com/p...products_id=80
nimblegimbal is offline   Reply With Quote
Old 11-29-2005, 06:43 PM   #18
andygold
Member#: 7347
2002 Impreza WRX
WR Blue
Any way to determine if the "replacement" is the liquid or solid type(before buying..any special part number)? Do the 2006 cars have the solid type, or are they still using the liquid filled ones?
Does anyone know if the Rear View Mirror w/ the homelink + compass works in a 06 STi? yo14jman Newbies & FAQs 4 09-14-2009 10:23 PM
Need help for HU in Above the Rear View Mirror clbd39 Car Audio, Video & Security 8 04-13-2006 10:48 AM
One Step method for removing the Rear View Mirror (no tools needed) Fish New England Impreza Club Forum -- NESIC 2 07-14-2001 10:20 PM
