Old 11-04-2005, 09:21 PM   #1
turboed22
Member#: 93364
1998 '98 Impreza RST
'14 BRZ
Default WRX Aftermarket headers onto RS Dohc heads
Does anyone know if a aftermarket header system will work on rs heads.
I have the ihi setup curretly with the swaped crossmember and everything.
Thanks
turboed22 is offline   Reply With Quote
Old 11-05-2005, 11:25 AM   #2
Andursun0013
Member#: 11616
1998 2.35RS-T
2006 Baja 2007 Leg. Wagon
well, if you have a stock WRX "header"/exhaust mani on there right now, there is no reason why an after market one won't fit that is designed to be a direct fit for a WRX
Kyle
Andursun0013 is offline   Reply With Quote
Old 11-05-2005, 12:11 PM   #3
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
^^^ It will be a direct fit like it was a WRX, since you've got the WRX crossmember installed.
Old 11-05-2005, 02:37 PM   #4
Unsung Boxer
Member#: 37196
just remember this wont change the crossmember issue. If you have DOHC heads, and a turbo crossmember, then the WRX Header *should* work.
Unsung Boxer is offline   Reply With Quote
Old 11-06-2005, 06:59 PM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
it was NOT a direct fit for me
Old 11-06-2005, 07:13 PM   #6
Andursun0013
Member#: 11616
1998 2.35RS-T
Did you happen to buy equal length or anything outside of the "factory" design??
Old 11-06-2005, 08:29 PM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
no factory
i needed a 1/16th inch spacer + the extra gasket needed while using a spacer to make it fit properly
im sure if i had access to different thicknesses of sheetmetal i could have used something just a little bit thicker for a better fit however, i was limited to stock on hand
Old 11-06-2005, 09:27 PM   #8
turboed22
Member#: 93364
'14 BRZ
I have modded legacy turbo manifold/up-pipe so I know I would have to change the up-pipe. I was just wondering about the manifold itself.
Thanks White
JDM Yellow Side Feed 480cc, EJ20K WRX TMIC, EJ20K Intake Manifold, DOHC Heads, etc. Audioexcels 1993 - 2001 Impreza Specific Parts 18 05-23-2010 03:24 PM
WRX cams into late '90 DOHC heads 2milehi Built Motor Discussion 9 08-07-2009 06:51 PM
WTB : RS DOHC heads, WRX/STi turbo inlet, crank pulley rs_two_five VIC Private Classifieds 3 12-20-2006 08:08 AM
RS DOHC heads for sale. Unsung Boxer North West Impreza Club Forum -- NWIC 1 08-05-2005 12:24 AM
FS RS DOHC heads/intake mani/exhaust Unsung Boxer Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-04-2005 10:11 AM
