Old 11-05-2005, 12:59 AM   #1
raider1v1
Member#: 99549
2004 WRX
Default changing oil types
so i did a search, and it said that just let it drain and maybe if i want do the engine oil cleaning thing. my question is what place can i go to have mobile 1 put in? the only place that is relatively quick is valvoline...do they have good oil?
and what do i need to have them do when switching from penzoil to a synthetic? just change it out?
raider1v1 is offline   Reply With Quote
Old 11-05-2005, 07:21 AM   #2
sjl1614
Member#: 56791
06 OBS
you need to remove the engine, take it apart and clean every spot of old oil off of it.....just kidding, put the new oil and your good to go
sjl1614 is offline   Reply With Quote
Old 11-05-2005, 11:53 AM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
1. Post in the right forum.
2. Read the sticky in the right forum.
Old 11-05-2005, 04:46 PM   #4
raider1v1
Member#: 99549
2004 WRX
how is this not the right forum? its in the description of this forum. i am sorry im new and not familiar with what goes where.
Old 11-07-2005, 05:40 AM   #5
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You originally had this posted elsewhere and I had to move it. Now that its in the right forum, read the sticky about oil.
Old 11-07-2005, 07:24 AM   #6
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Where are you? hard to recommend a location without that info!
No need to flush the engine, etc. - esp. if the car is reasonably low mileage (plus it isn't a great idea in high mileage cars either) - just drain the old oil, then fill 'er up with Mobil 1. Mobil 1 is compatible with conventional oils, so there should be no problems - just change the oil like any other time.
Old 11-07-2005, 07:42 AM   #7
raider1v1
Member#: 99549
2004 WRX
oh ok. well i am in kansas city, MO. i dont race at all. but sometimes its fun to just go a little faster than necessary. i live in an apt so i need to go to a place that has it in stock. do any places stock that oil?
what about valvoline do they make a good synthetic or regular oil?
Old 11-07-2005, 09:42 AM   #8
bluesubie
Member#: 767
04 FXT
bobistheoilguy.com - Is Valvoline really that bad?
-Dennis
Old 11-07-2005, 10:51 AM   #9
raider1v1
Member#: 99549
2004 WRX
so the moral of the story is that valvoline isnt that bad.
is it better to drive 25 miles to have mobile 1 synthetic put in or should i drive 5 and have valvoline put in? is the difference worth it?
edit: i did some checking and i can have an oil place just put it in for me, but what about the redline motor oils? should i use those or the mobile 1?
Old 11-07-2005, 12:28 PM   #10
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
What kind of car do you have?
Stanley is offline   Reply With Quote
Old 11-07-2005, 12:56 PM   #11
raider1v1
Member#: 99549
2004 WRX
04 wrx sedam 5mt 34k miles.
Old 11-23-2005, 04:22 PM   #12
Corkfish
Member#: 39503
Anyone have information or thoughts on mixing viscosities? I know the 5w-30 is controversial, so why not put in two quarts of 5W-30 and two of 10W-30? Does that translate into another viscosity that I'm missing?
Corkfish is offline   Reply With Quote
Old 11-23-2005, 04:47 PM   #13
hondaeater69
Member#: 60324
that would be 5.5W-30 mixing viscosities is fine. Get the valvoline if that's what's near you. different types of synthetic oil tend to disappear in our cars, so i would watch your oil level like a hawk until you can track it's usage regularly.
Old 11-25-2005, 02:47 PM   #14
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Any good quality oil is good, whether it is Valvoline, Mobil1, Redline, etc.
If you use non-synthetic (dino), plan on shorter oil change intervals than if you went with a true synthetic (ie; not some synthetic blend).
Dino oil change = ~3000 miles
Synthetic oil change = ~6000 miles
There are some synthetics calling for longer intervals between changes.
Dino is less expensive than Mobil1
Mobil1 is less expensive than Redline
Mixing your oil viscosities will probably yield you nothing. Just pick 1 viscosity of the brand you like and use that. Opinions of which exact viscosity/brand vary, sometimes greatly.
Samurai Jack is offline   Reply With Quote
Change oil first or start than change oil carpfish Service & Maintenance 5 03-23-2010 04:32 PM
Oil changes / oil type CVG993 Newbies & FAQs 9 07-24-2006 11:29 AM
Oil Change - does type matter? jcatcab Service & Maintenance 2 08-01-2005 12:54 PM
change oil filter with every oil change? BlackBeastie Service & Maintenance 1 03-15-2003 07:29 PM
