Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Old 11-05-2005, 01:45 AM   #1
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Default Needed new O2 Sensors? I think so
For about 3 weeks now i've been getting my CEL coming on for Cat Effieciency. After a couple of drive cycles it would go away then randomly come back at some other time. On October 21st I installed an Autometer AFR gauge and was happy with the results. But lately i've been watching it and its reaction was getting slower and cruising on the highway on a flat area, with cruise control on.
Well it started to show lean while cruising, even though my vac/boost gauge was still showing a load (~14 inHg of vacuum). This was bad I figured. So i ordered 2 new sensors from subarugenuineparts.com for about $230. I just installed them about 30 minutes ago. Started up my car and let the sensors heat up. Its a night and day difference on my AFR gauge, it was whizzing back and forth so fast while the computer figured out the fuel (reset the computer of course). No more part throttle misfires, runs alot smoother.
I'll get some pictures of the old O2 sensors in the morning, looking at them I am pretty sure the car was running really lean. Last time i changed an O2 sensor in a car they did not look white tipped like mine were.
This is just a reminder that if you suffer from part throttle misfire/bucking when the engine is cold or hot, and you can't figure out what it is (i changed plug wires, new filter, oil, etc.), it might be time to change your front O2 sensor. My car never gave me a code for the front O2, but it definitely needed it.
98 RS with 154,000 miles
need a new o2 sensor shoodoggy Private 'Wanted' Classifieds 12 01-23-2009 04:51 PM
Help, new O2 sensor and still CEL KimchiHo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-09-2002 01:25 PM
where to get new o2 sensor? NEWAGEWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-15-2002 02:27 AM
('93-'01) Need help guys! o2 sensor i think? GregBolby Impreza Forum 5 08-17-2001 01:48 PM
New O2 Sensor & ECM for MY00 Legacy GT! Jason Technical Forum Archive 16 09-08-2000 10:14 PM
