Old 11-05-2005, 08:36 AM   #1
Acadian
Member#: 31541
2003 WRX - Wagon
Default Leaky oil crush washer
Have you ever experienced a leaky crush washer?
This past Monday I did an oil change on my car Ė yesterday I crawled underneath to make sure my filter wasnít leaking, this after reading all the treads about the defective new oil filters F08, F09 and F10 (mine was a F05).
Like I do at all my oil changes, I used a brand new crush washer Ė but noticed a minute oil leak. Itís not leaving a puddle on the ground, but I can see a little bit of seepage around the nut.
Any of you ever experienced this? Should I change it or should I be fine until the next oil change?
Acadian is offline   Reply With Quote
Old 11-05-2005, 09:20 AM   #2
Hayes
Member#: 11808
Make sure it torqued to the correct value (32 ft/lbs I think) and live with it till the next oil change. Are we sure you removed the old one first?
Hayes is offline   Reply With Quote
Old 11-05-2005, 01:16 PM   #3
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Torque it down alittle more and replace it next oil change. I get to do the same thing but i'll probably change my oil sooner because of it.
Old 11-05-2005, 04:06 PM   #4
Acadian
Member#: 31541
2003 WRX - Wagon
Well I'm going to a local Subaru Tuner on the 17th for my 60k service...so I'm sure I'll be fine till then.
my car has 62,000 miles and I did all my oil changes yeah I'm sure I took the old one off and it's in the right position (e.g. Flat portion towards the head of the plug).
Maybe it was still dirty when I put the new crush washer on...oh well. I'm sure I'll be fine.
thanks guys!
Old 11-05-2005, 04:14 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Mine was leaking the first time I went to change the oil when the car was new. Might have been due to the fact that I have the oil temp gauge and they may have re-used the washer when the drain plug/probe was installed at the port or dealer. But no matter, right then I decided to forget about the crush washers and use solid copper ones instead. 75K later, I've never had one of those leak. I usually replace them at every change but have re-used them a couple of times with no problems.
Old 11-07-2005, 10:16 PM   #6
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Are you sure it is seepage or could it just be a little of the old oil you forgot to wipe away after you changed the oil?
Samurai Jack is offline   Reply With Quote
Old 11-08-2005, 10:50 AM   #7
Acadian
Member#: 31541
2003 WRX - Wagon
Been checking it daily - it's definitely a leak.
Old 11-08-2005, 11:18 AM   #8
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
33ft/lbs is very little torque. If it's overtorqued the fragile washer can easily offset and squeeze out a bit. And if it's overtorqued, torquing it more will not help, and could make it worse.
Jon Bogert is offline   Reply With Quote
Old 11-08-2005, 11:22 AM   #9
jebjkey
Member#: 73884
Chapter/Region: HIIC
2016 STi
HyperBlue
If you put the crush washer on backwards it will leak. The flat part should be against the oil pan and the round (crush) part against the bolt. The first oil change I got I did at the dealer and they put the crush washer in backwards (although I did not realize it at the time). I put it in backwards myself later on, which is when I realized which way to put it on. If it is bad enough, change your oil and put the new crush washer on correctly, if not, just wipe it as needed and fix it on the next oil change. And yes, if the bolt is not torqued to the right value the crush washer might leak even if it is installed correctly.
jebjkey is offline   Reply With Quote
Old 11-08-2005, 01:11 PM   #10
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
OK, so you post information that directly contridicts conventional wisdom, all known writings on the subject and recommendations from Subaru themselves. PLEASE tell us that you're not basing that pile of poo solely on the recommendation of some 80 IQ grease monkey at your local Subaru dealer.
if you have good data, please post it. Otherwise, have some consideration for the noob doing his first oil change who might read your post and think it was accurate.
Old 11-08-2005, 01:47 PM   #11
taylor04
Member#: 78752
2005 WRX Sedan
WRB Pearl
I would rethink that statement
taylor04 is offline   Reply With Quote
Old 11-08-2005, 05:14 PM   #12
Acadian
Member#: 31541
2003 WRX - Wagon
no kidding.....I would hate to be a newb reading his post!
yeah maybe I over torqued it... either that or some grit got lodged between the crush washer and the bolt and/or the oil pan.
Either way, Iím just going to keep a close eye on it until and maybe add a bit of oil until the 17th - at which time Iím bringing my car in to a local tuner for her 60k service.
I think this was a good exercise Ė why? Well usually I never pay attention to the bolt after doing oil changes. I typically do my oil change, run a car for a bit and look under to make sure everything is peachy then assumed all was fine! I never inspected the filter/bolt the next day. Iíll be doing this from now on to make sure there arenít any slow leaks like these Ė AND Iím going to have to stop being a torque monkey
Old 11-10-2005, 06:59 AM   #13
Acadian
Member#: 31541
2003 WRX - Wagon
well I got paranoid and went ahead and changed my oil again and replaced the washer.
Guess I had over torqued it
Leaky power steering banjo bolt crush washer gopsu Newbies & FAQs 5 08-19-2009 05:00 PM
Anyone ever had a leaky 6 speed? What crush washer?? eightballrj Transmission (AT/MT) & Driveline 2 01-03-2004 02:48 PM
Need to buy crush washers for oil change, where? Necromancer Bay Area Impreza Club Forum -- BAIC 7 08-06-2000 09:50 AM
Oil plug crush washers? yakker Technical Forum Archive 18 06-09-2000 07:39 PM
