11-05-2005, 05:19 PM | #1 |
Guest
Member#:
Another knock thread
No I dont have logs.
BUT...this confuses me. I spent about 2 hours on the dyno with my RX getting a good safe map into it...AFR's are good, around 11:1...and timing is very conservative. Only running 7psi...the stock wastegate presure. I was getting good power over stock....but with some knock here and there...so I went to those areas...pulled timing...then it was there...and here...repeat. Spent an hour doing so. Finally, no knock on repeated pulls on the dyno. yay! But, no more power than when I started...bah, its 2am, time to go home. Save...make sure ECU has it...done. Next morning...KNOCK KNOCK KNOCK like someone was at the door. WTH?!?!?!??! The ambiant temps didnt change much from 2am to 9am...maybe it was ~5 deg warmer in the morning when I went back to work. what gives? Mod list for 1987 SUBARU RX, stock engine and internals: MegaSquirt Version 2 TWE Header/Donwpipe w/catless 2.5" exhaust 'cold air intake' Air-Water Intercooler 2 step colder NGK plugs Stock boost on stock turbo(7psi from 2400 to redline, 6500) thats it. Pretty basic 'bolt ons' for this car. any ideas?
11-06-2005, 08:28 AM | #2 |
Member#: 10823
Vehicle:2007 STi Silver |
Perhaps your making more load on the street than you were on the dyno and you are operating in a different load range?
11-06-2005, 02:54 PM | #3 |
Guest
Member#:
a possibility...but, the 3rd gear pull on the street is shorter than the pull on the dyno...?
11-06-2005, 07:43 PM | #4 |
Member#: 10823
Proof that you are making more boost and power on the street. Try tuning in fourth or fifth to build more load at lower RPM...
11-06-2005, 07:44 PM | #5 |
Guest
Member#:
well, ive noticed that on any car we've put on the dyno....unless we do the pull in 4th/5th (on a 5spd car)
11-07-2005, 10:28 AM | #6 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
humidity plays a big role too.
what kind of sensor inputs are you using for your MS maps? ie maf/map/iat etc? speed density or maf based? |
11-07-2005, 10:49 AM | #7 |
Guest
Member#:
MAP built into the MS, speed density.
IAT TPS |
not a typical engine knock thread | 05BlooSTi | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 9 | 06-02-2009 03:30 PM |
Another Rod Knock Thread | scaryc | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 05-31-2009 08:19 PM |
Another knocking question, maybe piston slap, but... | 2bluewagons | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 04-24-2008 03:30 PM |
Another WTF is this knock thread. | DinoGuan | UTEC | 10 | 12-31-2007 10:38 PM |
oh no, not another Rogers thread from me!! | jackwei | Vancouver Impreza Club Forum -- VIC | 7 | 11-13-2001 05:37 PM |
