11-05-2005, 11:29 PM | #1 |
Member#: 72588
How well does Ecutek correct knocking??
Compared to other ecu (utec), does ecu correct knocking well??
11-06-2005, 09:09 AM | #2 |
Member#: 47145
Vehicle:2012 Gas Saver |
if your knocking you have a problem, too little fuel, too much advance, too much boost.....correct it....
Ecutek is one of the best EM available to the market....finding a good tuner is what is critical.... |
11-06-2005, 09:35 AM | #3 |
Member#: 72588
when my car get tuned, my knock meter shows no signs of knocking. only very few times in high rpm, it detect knocking. so should i re-tune it??
11-06-2005, 09:49 AM | #4 |
Member#: 47145
it could just be winter gas causing a slight knock, the ecu should correct for winter gas....
11-06-2005, 09:57 AM | #5 |
Member#: 72588
Will EJ257 ecu turn to be safe mode when knocking after ecuteked?
11-06-2005, 09:57 AM | #6 |
Member#: 47145
11-06-2005, 10:44 AM | #7 |
Member#: 67080
EcuTek is no more then software used to change the OEM ecu tuning maps. That's all it is and will always be. The capability of the knock corrections to keep knock down is all a capability of the OEM ecu which is a very advanced system in design. This is one of the major reasons why I like flashable solutions for EM on our cars. If knock is detected in a certain area, the ecu will change the KC values it uses in that area and the knock will not happen again. Of course if the tuner that tuned your car pushes the envalope of the tune to the max and doesn't create a map that the ecu can learn and advance itself you'll have issues as well.
How well does Perrin silicone blue match Samco silicon blue?? | eightballrj | Interior & Exterior Modification | 3 | 02-08-2004 10:52 PM |
How well does the 4EAT WRX trans hold up? | JDMSubaru | Transmission (AT/MT) & Driveline | 5 | 12-01-2003 11:41 PM |
Aftermarket WRB Paint... How well does it match OEM? | thejean | Interior & Exterior Modification | 4 | 04-23-2003 07:00 AM |
How well does your E brake really work? | Aaron'z 2.5RS | Brakes, Steering & Suspension | 11 | 09-12-2002 07:22 AM |
How well does the Subaru do off the pavement? | oney01 | Newbies & FAQs | 8 | 09-03-2002 09:17 AM |
