Old 11-06-2005, 08:15 AM   #1
DetroitWRX
Member#: 18777
2002 WRX Wagon
Sedona Red Pearl
Default hard to move doors
My front doors are hard to open and close. The drivers is really bad. I have lubed everything with different tyoes of lube and nothing works. Now that I have a commuter beater I only drive maybe 3-8 times a month. Is the lack of use creating stiff doors?
DetroitWRX is offline   Reply With Quote
Old 11-06-2005, 08:28 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
What type of lube did you use and where did you apply it? A good-quality spray lithium grease, applied into the hinges, should take care of this. The spray enters the hinge in liquid form and then sets up as a white grease that remains after the carrier evaporates.
Old 11-07-2005, 12:42 PM   #3
WilkinsSubaru
Vendor
Member#: 43552
:o) Need Parts Now?
Agreed with Mulder...
Jackie
WilkinsSubaru is offline   Reply With Quote
Old 11-07-2005, 12:50 PM   #4
DetroitWRX
Member#: 18777
2002 WRX Wagon
Sedona Red Pearl
Used what I normally put on door hinges, good white lithium, first and it did not work. Then used dry graphite, plain household oil, 30w, and a non-drying penetrating lube, and good grease. I put it on the hinges and the plastic bar thing. I have been trying to figure it out for about 6 months now. Is it possible parts could be warn or broken, and if so what?
Old 11-07-2005, 03:20 PM   #5
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
I was the only one in my car every day (2000 RS) for a long time. T drivers door is still "loose" (in a good way) and the passesnger door is a bit stiff.
Someone recomended some spray, I have yet to try it out. Here is my thread on this
http://forums.nasioc.com/forums/show...highlight=door
moogoob is offline   Reply With Quote
How hard would this be to do, to move the fog lights??? shamrock 05 Interior & Exterior Modification 9 11-12-2008 07:20 PM
After accident, shifter is hard to move bmw50021 Transmission (AT/MT) & Driveline 2 05-21-2007 07:54 PM
AT shifter hard to move in GF's 99 OBS mentat Transmission (AT/MT) & Driveline 0 07-26-2006 06:13 PM
2004 was a hard year. Time to move on but I cant.. Wheels Off-Topic 15 01-02-2005 12:05 PM
is it hard to take off the door panel? jacktam1 Vancouver Impreza Club Forum -- VIC 5 11-01-2001 03:26 AM
