Welcome to the North American Subaru Impreza Owners Club Wednesday December 7, 2016
Old 11-07-2005, 01:37 PM   #1
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Default WRX Turbo Stuff on 99 2.5 DOHC (Intake Manifold Question)
Have any of you guys with 2.5s been able to simply swap the crossmember in your car and install WRX intercooler, headers, up-pipe, down pipe, intake and Y pipe? Or is there enough of a measurement difference between the intake manifolds to cause it not to fit?
Brad
MY99 2.5GT is offline   Reply With Quote
Old 11-07-2005, 03:33 PM   #2
Stealth_RS
Member#: 95677
2004 WRX
man I want to do this same thing!!
Stealth_RS is offline   Reply With Quote
Old 11-07-2005, 03:54 PM   #3
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Yes, it should all fit but you may need to use a spacer on the uppipe to get it to clear the head. The intercooler is usually a tight squeeze.
Master2192 is offline   Reply With Quote
Old 11-07-2005, 05:18 PM   #4
turboed22
Member#: 93364
1998 '98 Impreza RST
'14 BRZ
Some modification is required for the intercooler.
I run a wrx tmic with a 98 intake and I had to shave my throttle body the the outlet of the intercooler but it fits and works perfect. You might have some coolant lines in the way depending on your turbo set-up.
turboed22 is offline   Reply With Quote
Old 11-07-2005, 05:48 PM   #5
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Ohh, and I don't know if you've got cruise control..But your either going to lose cruise control or find a place to relocate the cruise control box...
I might just remove my cruise control...
Old 11-07-2005, 06:49 PM   #6
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
Do you mean a complete motor swap? If so, yes .
joubtt is offline   Reply With Quote
Old 11-07-2005, 07:34 PM   #7
Stealth_RS
Member#: 95677
2004 WRX
ok so it works some one please make a list of everythying that i would need so i can start shopping
Old 11-07-2005, 07:38 PM   #8
darioc
Member#: 35695
02 RST
98 Outback 92 Wrangler
need for what?
darioc is offline   Reply With Quote
Old 11-07-2005, 08:23 PM   #9
Stealth_RS
Member#: 95677
2004 WRX
to make my RS turbo with WRX parts!
Old 11-07-2005, 08:24 PM   #10
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
I posted all that info already in your other thread..........
Anyway, yeah it can be done and it's been done a thousand times.
Also, you will find more useful information on this one website pertaining to exactly what you are doing than any other website:
http://uniquemotorsports.com/jon/
-Brett
ExecNav is offline   Reply With Quote
Old 11-08-2005, 02:16 PM   #11
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
So trim the TB down a little and the intercooler will fit without shoe-horning?
I was hoping to use an aftermarket cooler. Hopefully I can find one that isn't any larger between the TB and Firewall but has some extra thickness and width.
So Cruise Control will need to be relocated?! Or tossed!! Thats an item I will need to do to eyeballing as to where else it will fit. I definitely want to keep that.
So as long as the X-Member is a WRX or Turbo Legacy I shouldn't have any trouble with WRX headers/up-pipe/Down Pipe but may need to add a little extension to fit the turbo in the right place?
Brad
Old 11-08-2005, 02:58 PM   #12
Master2192
Member#: 83254
98 2.5 RS
04 WRX
looks like you got it all figured out.
WTB: 2.5 dohc intake manifold 94legacy2.2 Private 'Wanted' Classifieds 6 02-21-2009 02:45 PM
wtb 2.5l dohc intake manifold stibf Private 'Wanted' Classifieds 3 02-23-2008 09:58 AM
8.5mm performance ignition wires for a 97-99 2.5 DOHC subygirl Private 'For Sale' Classifieds 12 05-22-2006 07:15 PM
WRX/STI Manifold/TGVs on 99 2.5 DOHC Heads? MY99 2.5GT Normally Aspirated with bolt-on Forced Induction Powertrain 17 02-03-2006 09:55 PM
wrx turbo kit on 02 2.5 RS taeyax82 Normally Aspirated with bolt-on Forced Induction Powertrain 1 03-12-2004 10:44 PM
