Welcome to the North American Subaru Impreza Owners Club Saturday August 23, 2014
Closed Thread
Old 11-06-2005, 05:31 PM   #1
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
Default EJ22T is a piece of poop. EJ22T rundown from supermoose perspective
word. this thread is designed to rile things up....
Ej22t is a piece of poop. its like a 45 year old hottie, the problem is the 45 year old part....its only worth picking up if you pay somthing like $400 bux for it.
for the fanboy bandgagon jumpers that like to say that its the strongest blah blah blah - you're idiots. how many fanboys of the EJ22t have actually owned one or had a chance to compare it to all the other great subaru engines out there?
SOHC HLA heads, no intercooler, rudementary EMS in comparison to EJ20G of the time, tiny turd turbine, etc etc. AN EJ20G closed deck is a stronger block than a EJ22. use brain think- thicker walls, same closed deck and oil squirters, ANY it was availible with STI forged pistons, STi blueprinted and built. AND u can get them with 50,000 miles and 8500 RPM heads. try that with a pile of crap USDM SOHC with 150,000 turd miles. youll spend most your time cleaning off the frekin EJ22t so u can look at it and touch it without making your hand full of poop grease.
Closed deck is meaningless to pretty much everyon on this forum ex for soon2bgreat, and even then he makes 500 wheel on OPEN DECK (yes, its semi-closed but not much differnt from open imo). perhaps at 500+ wheel it makes a diff, ive seen plenty of open deck 300 wheel daily driven EJ205's, and the only thing that goes on those guys is the ringlands from the ones ive ran into. however, i dont play with usdm - my brain is in JDM land......
the phase 1 closed deck blocks have weaker crankshaft bearing layouts than the open decks. YES, i have ran a closed deck EJ20, YES i did spin it to almost 9K on the track, and yes it did spin a rod bearing for some reason or other - yet to be determined. AND YES the crank/bearings/rods are identical to the industructale EJ22t.
if you think a EJ22t will spin to taht in sorry 150K mile condition and not blow up, you are sorely mistaken.
EJ205 > ej22t ANYDAY. the only decent part of the EJ22t is the shortblock, its the cheap trick to a slightly bigger displacement block.
EJ205 in my opion is a bit un-optimized and hindered, BUT it is a good engine. walk any EJ22T at however much money with more than 50% of stock parts. hahah.
so all you fanboys of ej22t whatevers..........good luck with your 16 second 1/4 miles. those with realistic viewpoints that have a EJ22t in your impreza, i give you props for keeping an OG powerplant alive. for those pondering the swap, i suggest a EJ205 or a JDM EJ20.
but, in summation- EJ22t is a piece of poop.
yes, my RA will walk a GTR...
supermoose is offline
Old 11-06-2005, 05:52 PM   #2
JoshP
Member#: 94350
Originally Posted by supermoose
word.
ej22t is a whole 4 years older than your beloved v2.
all valid points. Nothing to argue here.
we figured that out a long time ago, but thanks for reverbarating it.
whatever, ive never seen a 22t with a spun bearing, yet ive seen dozens of wrxs with them personally. Let alone the wrx guys on here.
absolute rubbish. Xephyr did it with a 150k mile more, in fact he spun it much higher than you lost your bearings at before he lost his.
in a lot of ways yes. But it really should be considering it generally costs 4X as much as a 22t would cost you, and id still take a 22t personally.
agreed.
yes, there are at least 2 ej22t powered cars on this forum that would walk your car. cheers
JoshP is offline
Old 11-06-2005, 06:00 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Sounds like someone woke up on the wrong side of bed.
I'm not going to argue the lower points of the "turbo legacy" Some of the things you mentioned have nothing to do with the block itself, but rather how the turbo legacy was setup. As a complete engine, about the only things I'd say that really could use some work is the heads. They valves aren't too large, and the hyrdaulic lifters.....your comment about the EJ20G block being stronger because it's thicker is poop. The casting is going to be roughly similar, the sleeves will be different. Irregardless, we're talking small amounts of aluminum that really isn't going to make a hill a beans different.
Legacy777 is offline
Old 11-06-2005, 07:05 PM   #4
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Great, that is your opinion. however, after seeing rally teams and tuners using them (even replacing the sti block with the 22t) i am going to believe them. especially with talkingwith guys over at legacy central and finding out the crazy things they have done to them.
are you still cranky for getting your car hit then vandalizing someone else's?
bmxpunk is offline
Old 11-06-2005, 07:11 PM   #5
JoshP
Member#: 94350
I dont understand why everyone has a vendetta against the ej22t, although I have a theory. But ill keep it to myself
JoshP is offline
Old 11-06-2005, 07:14 PM   #6
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Eh, my junkyard ej22 with rs heads went 12.44 @107 at 5800ft above sea level. On a small t3/t4 turbo. I paid $250 for the shortblock. ALL subaru longblock, link ems and modded wrx inejectors with a tiny topmount. Stock tranny and exedy clutch- stock open rear diff too. Walk what? The new setup will also be ej22 powered, but with a 2.5 crank as well. Should be out first race next season. I expect to drop alomst 3 seconds on my previous time with my new setup. I have changed EVERYTHING since then.
However, ej22t's are getting harder and harder to find in decent price with fairly low milage. In the next build I might just push an ej257.
Drac9 is offline
Old 11-06-2005, 07:15 PM   #7
turbocolin
Member#: 43539
95L 97L 03hedgehog
02 wag 180mph monster
what about the 22t block with 205 heads running 2.0 ems tuened for 2.2
turbocolin is offline
Old 11-06-2005, 07:27 PM   #8
Whiteghost 2.5
Member#: 72994
2001 Racekor
Emerald Green
or a 2.2t running Ver2 RA heads and forged 100mm pistons, and other assorted goodies?
Josh
Whiteghost 2.5 is offline
Old 11-06-2005, 09:08 PM   #9
RollingOnAll4
Member#: 30109
2000 full blown
Dirty Whore
Impreza GC8
I can name one located in South Florida going under the nic name "Sling Shot"
RollingOnAll4 is offline
Old 11-06-2005, 09:17 PM   #10
JoshP
Member#: 94350
thread backfire
JoshP is offline
Old 11-06-2005, 09:42 PM   #11
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Agree with josh that the layout wasnt well sorted for the poor ej22t, but how many parts do they really share??
I was standing in Matt Monson's garage three weeks ago and he hands me 2 pistons, one for a 22t and one from an RA, he looks at me and says of the 22t " not forged like the RA ones but still super strong, great little motor really"
not to mention(as quoted by your first post) you are comparing sti prepped & blue printed to a production engine. hmmmmm
bmxpunk is offline
Old 11-06-2005, 10:17 PM   #12
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Yes they suck, don't buy 'em.
More for me!!11
-paK +3
Pakin is offline
Old 11-06-2005, 10:17 PM   #13
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
Moose this isnt the best way to prove your point. You cant compare your engine to a EJ22t just like I cant compare my engine to yours and yet someone with a Ver 7 spec C cant compare their engine to mine.
It is much better to state facts about the EJ22t engine and let people come to their own conclusions.
Scoobie Steve is offline
Old 11-06-2005, 11:16 PM   #14
supermoose
Member#: 9093
swap starr
haha. i just wanted to rile things up a bit.
i honestly dont care who walks who. my G is a bit on the slow side imo.
i just dont enjoy the hype about the EJ22t. its just a old motor with some good bits.
Old 11-06-2005, 11:21 PM   #15
turbocolin
Member#: 43539
95L 97L 03hedgehog
i hate you
Old 11-06-2005, 11:26 PM   #16
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Moose =
Old 11-06-2005, 11:30 PM   #17
supermoose
Member#: 9093
swap starr
hahha. we all know that a EJ22t shortblock transplantted into a set of good heads (sohc JE25) or EJ20X is good.
rumpus rumpus rumpus
Old 11-06-2005, 11:31 PM   #18
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
What?
Wedge is offline
Old 11-06-2005, 11:53 PM   #19
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
EJ22T engine = eh/not worth the wiring hassle for the performance in a swap...engine management isn't easy like a sti/wrx swap...also the engine is no doubt old and most likely could use a rebuild...
EJ22T block = worth it for high horsepower, more specifically high boost applications...
just my $.02, Micah
Homemade WRX is offline
Old 11-06-2005, 11:55 PM   #20
supermoose
Member#: 9093
swap starr
i concur. my point EXACTALLY.
although, you can buy a good condition EJ20G closed deck shortblock for less than a EJ22T block in need of rebuild will cost you....
me=too lazy to rebuild things....any my powergoals not nearly as lofty as many.
Old 11-06-2005, 11:57 PM   #21
Homemade WRX
Member#: 33782
96 bastard child
I'm glad we see eye to eye
can I have your car...so I can put my stuff in a wagon ?...j/k
I need a wagon that can walk a GTR
Old 11-07-2005, 12:07 AM   #22
supermoose
Member#: 9093
swap starr
hahah. well, the walking a GTR is obviously conditional - 0-80 :P
Old 11-07-2005, 12:12 AM   #23
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
right, moose, the one thing you, and everyone else missed in this thread is its not an ej22t, its an ej22G
what does that mean??
same basic design as your old block. the block is good, its not great.
im just not a fan of phase 1 any more. the real 2.2 block worth a damn is the one i dont even need to say. its not a legacy turbo block,(even though its still labled as an ej22G) and if you dont agree with me on that, ill wait for matt to chime in on the subject.
and why compare heads? legacy turbo heads just blow nuts
Hurley 2.5 WRS is offline
Old 11-07-2005, 12:15 AM   #24
Homemade WRX
Member#: 33782
96 bastard child
I gave up on calling it that because everytime I'd post it I'd get people asking what it was and the occassional rude asshat telling me to burn in hell...
ROFL...waiting for the flow bench numbers and people to stick up for it...I know my WRX heads suck and I'll admit it...now wait for them to compare the two...
Old 11-07-2005, 12:15 AM   #25
JoshP
Member#: 94350
no, its not. The engine code actually is ej22t, ej22g is the 22b STi engine
they flow 75% of what wrx heads do.
JoshP is offline
Closed Thread
what a piece of poop imprezaowner27 Member's Car Gallery 16 04-27-2009 10:49 PM
So there is this piece of watermelon in the kitchen at work right... BTR Off-Topic 23 07-20-2007 11:31 AM
My Car Is A Piece Of Crap StangGrl Off-Topic 58 11-09-2005 01:15 PM
Norton Systemworks is a piece of **** Full_Clip Off-Topic 3 08-12-2004 06:25 PM
Just found out my car is a piece of crap! Corn-Picker Off-Topic 44 06-16-2004 09:34 PM
