11-06-2005, 07:33 PM | #1 |
Member#: 58926
SWIC
Vehicle:2013 WRX 5dr ISM 2011 Infiniti EX35 |
Cobb AP - Replace restrictor hose too?
The cobb web site has instructions on replacing the the restrictor hose. I know this is easy, but I didn't know that it was needed for the AP install. Any info?
Edit: Never mind, I just read that it was in case peak poost does not reach target of 14.7 for stage 1.
11-06-2005, 08:30 PM | #2 |
Member#: 67080
That does not even apply anymore. That was back in the AccessECU days.
11-07-2005, 03:08 PM | #3 |
Member Status: Member
Member#: 46241
SWIC
Vehicle:- Can I get a wayo |
It does still apply. To clear up any confusion:
If you arent hitting target boost, the restrictor hose can be the first thing to check. Often the hose will be modified or in poor condition, This will cause the car to deviate from target boost. The AccessECU Re-flash has the same behavior as the AccessPort maps. The only difference is that the user can control the map being used on the ECU. |
wtb: 06 parts, Cobb AP, 16G or vf39, samco hoses | uniden43 | Private 'Wanted' Classifieds | 3 | 05-24-2006 12:57 PM |
Does cobb AP give you a new restrictor to replace the 1/8 stock one like Vishnu does? | mrtrex | Engine Management & Tuning | 3 | 11-13-2005 11:08 AM |
cobb ap stage 1 with turbo inlet hose and others | DesperodoZ | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 07-19-2005 02:34 PM |
Cobb 2.5 vf30 restrictor/hose question | earlmale | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 10-03-2004 08:56 AM |
Cobb AccessECU restrictor hose | allythom | Engine Management & Tuning | 16 | 12-09-2003 12:31 AM |
