11-06-2005, 10:09 PM | #1 |
Member#: 69621
TXIC
Vehicle:05 mines wrx RIP still hatin ROTAS |
AP with top mount
Im gonna run AP stage 2, and later on add a pnp td04 and the jdm sti top mount, will the AP be able to handle this as long as I dont race the car alot? Im in texas so there are not alot of options as far as getting tuned.
11-07-2005, 01:58 AM | #2 |
Member#: 77483
NWIC
Vehicle:2009 Audi A3 2.0T q Lava Grey |
AP will handle the TMIC no problem. Wont get nearly as much out of it as with a profesional tune, but you wont blow up the car either/.
11-07-2005, 06:27 AM | #3 |
Member#: 55923
you have ST, is it easy to use ? what are your mods?
have you tuned your car with ST ? did you change timing etc. ? |
11-07-2005, 12:56 PM | #4 |
Member#: 77483
NWIC
ST is pretty easy to use. I find it easier than the UTEC. My engine mods are basically just a TBE, but shortly (when I find the time to install the crap sitting in my garage) to be a VF39, injectors and fuel pump.
I have tuned the car, and yes, have added a bit of timing to some locations on the map. |
11-07-2005, 04:36 PM | #5 |
Member#: 55923
do you think I can start by using a stg 2 map and then tune with ST ?
and will the car start and run with the only stg 2 map ? |
11-07-2005, 05:10 PM | #6 |
Member#: 77483
NWIC
The car will start, but run QUITE poorly. Your best bet would be to find someone on wrxforums.com with a similar setup, get them to send you their map, and tune from there.
11-07-2005, 10:36 PM | #7 | |
Member#: 69621
TXIC
11-07-2005, 11:04 PM | #8 |
Member#: 77483
NWIC
No, I'm saying that on a Stage 2 map your car will run like ass. On a proper map (AP, EcuTek, UTEC, StreetTuner), you car will run fine.
You dont seem to be getting this. Lemme make it REAL clear: *****WITHOUT A PROPER MAP DESIGNED FOR YOUR TURBO/INJECTORS, YOUR CAR WILL RUN LIKE ASS. WITH A PROPER MAP, IT WILL RUN FINE.****** |
11-08-2005, 11:44 AM | #9 | |
Member#: 69621
TXIC
Which is a huge differnce, because my version of running like ass is barely drivable, while what i think you mean is fine for driving around just not racing alot, or constant track runs. |
11-08-2005, 11:53 AM | #10 |
Member#: 77483
NWIC
Its in between. The car will run well enough to take a 50 mile drive to your tuner.
Think of it this way. Your stock injectors flow about 440cc. The pinks flow about 565cc. Thats a ~25% difference. If you run the car with mapping designed for stock injectors (e.g. a Stage 2 map), the car will be shoving in 25% too much fuel at every load point. Thats incredibly, over the top rich. The car WILL run, but you'll get plenty of black soot on your bumper, nice unburned gas smells, probably some idle problems, very likely some stumbling issues, to say nothing of poor performance. Its FAR closer to the 'not running' side than the 'not running optimally' side. |
11-08-2005, 01:30 PM | #11 |
Member#: 55923
my stock injectors are 380 cc (but I switched to pinks).
are US WRX stock injectors 440 cc ? |
11-08-2005, 02:11 PM | #12 | |
Member#: 77483
NWIC
11-09-2005, 01:08 AM | #13 | |
Member#: 69621
TXIC
Thank you for proving that you have no clue what you are talking about and your opinion invalid |
11-09-2005, 07:17 AM | #14 |
Member#: 48307
SCIC
Vehicle:02 bugeye hbspeed tuned 18g sleeper |
an upgraded top mount shouldn't give you any problems w/ stage 2. it's a bit overkill to get a bigger intercooler with the stock td04, however. a version 7 will be a perfect upgrade for a stage 2, but you'll want a bigger bar and plate when you go 2.5. As always, a custom tune is best, but the off the shelf maps will work.
11-09-2005, 10:43 AM | #15 | |
Member#: 69621
TXIC
11-09-2005, 01:02 PM | #16 | |
Member#: 77483
NWIC
I do know what i'm talking about, but missed an element of the setup there. Last edited by mcowger; 11-09-2005 at 01:33 PM. |
11-09-2005, 01:03 PM | #17 | |
Member#: 77483
NWIC
11-09-2005, 05:22 PM | #18 |
Member#: 49825
NESIC
Vehicle:2002 WRX WAGON SILVER |
I have been running a Hyperflow tmic on my ride for 2 yrs. Started @ stg. 1, now stg.2 HWG. w/turbo back. Never a problem, and have done 0-60 @ 6.1 w/ a 4eat tranny. Gutted u/p helped to eliminate that lag problem, and that time was without brake torquing.
11-09-2005, 11:12 PM | #19 | |
Member#: 69621
TXIC
Set of LIKE NEW GR2 with spring with top mount, already assembled | qualityracer | Suspension/Brakes/Handling | 0 | 12-04-2008 04:45 PM |
turboxs rfl with top mount adapter | Ammata | Engine/Power/Exhaust | 7 | 08-28-2008 09:15 PM |
18g with top mount? | fsmwrx | North West Impreza Club Forum -- NWIC | 2 | 03-03-2008 05:51 PM |
FS: FAT Turbo Kit Complete with Top Mount and J&S | BretCutler | Engine/Power/Exhaust | 0 | 08-16-2006 09:56 PM |
Who has the fastest WRX with top mount intercooler? | N/A01RS | Proven Power Bragging | 11 | 10-04-2002 05:28 PM |
