11-07-2005, 11:39 AM | #1 |
Member#: 96164
Vehicle:2005 STi - SOLD :( '00 Impreza 2.5rs |
Race gas info? (or higher octane)
I currently have a Protune map for 93 octane pump gas and I'm wondering if I'll see an increase in power if I run a higher octane gas?
I've heard the STi's ECU will only adjust itself up to 95 octane, any truth to this? What would my best bet be if I wanted to give this a try? I don't have any cats, so I don't know if I'd be better off using a leaded additive or if I should just keep it unleaded I honestly don't have any real experience with trying to up the octane of my gas on this car. Thanks for any help. PS: I don't have a map made for race gas, I'll be using the Protune 93 octane map.
11-07-2005, 01:53 PM | #2 |
Member#: 56468
NWIC
Vehicle:04 Improved STI Dirty White |
You can likely increase power with octane, but you will have to alter the tuning to do so. The ECU will adjust "closed loop" fueling (it's a loop of optimization) but not "open loop". You are talking about power during WOT, and that is "open loop" fueling. There is some adjustment made by the ECU even during open loop, but that is usually in response to detonation (which hopefully you don't have going on right now).
If you are running the stock turbo and injectors, don't bother with race gas. |
11-07-2005, 06:56 PM | #3 | |
Member#: 60142
Vehicle:2011 WRX Grey |
OTOH, if you're only talking about daily driving, I agree with bboy - you're simply wasting money. |
11-07-2005, 07:11 PM | #4 |
Member#: 28650
TXIC
if you have a datalogger you can watch what the car is doing. There's a free datalogger out there that seems to work well. I'm using streettuner. My protuned map is a little on the aggressive side and so the car pulls some timing on pump gas. In my case I do see a benefit from race gas, but it takes about 8 long pulls for the ECU to learn it's safe to start ramping timing back up. Once it gets to the advance set in my maps, it stops advancing timing. Fueling seems to be unchanged.
Long story short, if your map is tuned to the ragged edge, you might see a benefit from higher octane gas. If not, it's of no benefit. If you want to know for sure, run some logs and look at the total advance or dynamic advance values. |
11-07-2005, 08:47 PM | #5 | |
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
11-08-2005, 05:21 PM | #6 |
Member#: 89995
Vehicle:05 Broke STI |
Well ive run race gas on my TurboXS dynomap that was tuned on 93 and i swear your car just feels smoother (prob in my head) Plus race gas smells good
11-08-2005, 05:59 PM | #7 | |
Member#: 56468
NWIC
11-09-2005, 11:27 AM | #8 |
Member#: 67518
NESIC
Vehicle:2013 Focus ST TB |
I use Sunoco 94 with 93 oct map.
I noticed a difference when I started using the 94 vs 93 The power delivery feels a lot smoother with it |
Race Gas / Higher Octane Gas | 2Quick | South West Impreza Club Forum -- SWIC | 30 | 03-04-2007 08:54 PM |
Higher boost and race gas. | bryan carbon | Proven Power Bragging | 12 | 05-06-2003 12:53 AM |
Local guy for race gas/delivered or pick up/ 5 gal | Tex-WReX | Texas Impreza Club Forum -- TXIC | 8 | 06-26-2002 04:42 PM |
Cam2 or any other type of race gas | SubyNewbie | Mid Atlantic Impreza Club -- MAIC | 7 | 05-13-2002 07:39 PM |
Where to get race gas, Westchester area or north | IMPREZIV | Tri-State Area Forum | 1 | 08-29-2001 03:52 PM |
