Old 11-07-2005, 11:55 AM   #1
Alan l.
Member#: 90085
Default Cobb stage 2 wastegate flutter......
I have a stage 2 4eat wagon with about 4500 miles. Never did it until recently. My wastegate arm is about 3 turns tighter than stock and my AP shows I am at correct boost levels.
If i step on it from the start, the car accelerates hard/normal with no flutter but lets say the light turns green and i press the gas lightly for the first 2-3 seconds but then decide to really floor it, i would get a flutter/tapping sound coming from the engine. Is this what they call wastegate flutter??
Sounds like a metallic tapping sound but it doesn't always happen. Only sometimes and under the above situation.
Does this mean that i should go alittle tighter with my wastegate arm?
thanks,
Alan
Alan l. is offline   Reply With Quote
Old 11-07-2005, 12:49 PM   #2
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
thanks,
Alan
No, it means it's TOO tight. You're pushing more air into the engine then the tune will process out.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 11-07-2005, 12:57 PM   #3
Alan l.
Member#: 90085
Hey Jorge,
I wanted to get my car protuned by you when you were in the tri-state area but it was all booked up. Next time
Could you explain to me how you know its too tight rather than too loose? I always thought when theres WG flutter, its because its not tight enough and if its too tight, the WG doesn't open at all = no flutter? Sorry, i'm a total newb with this
Thanks
Alan
Old 11-07-2005, 01:16 PM   #4
subieworx
Member#: 47769
Sounds like det to me.
subieworx is offline   Reply With Quote
Old 11-07-2005, 01:39 PM   #5
Alan l.
Member#: 90085
woah...now your scaring the **** out of me
To add, I've been stage two for about 2K and i just started to notice this. Again, only happens like how i mentioned above from stand still or slow very slow speeds. The car drives fine otherwise. I hope i didn't ***** anything up!
It sounds like a an exhaust flutter though. Its pretty loud and you def. hear it from inside the car with the windows up or down. Tap tap tap tap like noise. If i floored it from the light the car doesn't make that noise (WG stays shut) but if i part throttle it (WG slightly open) and then decide i want to floor it, the WG is trying to close but not fast enough causing the flutter or am I not understanding how it works completely?
Old 11-07-2005, 03:13 PM   #6
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
My wastegate flutter is a very distinct "pfft pfft pfft pfft" sound. For reference, I have the Scoobysport downpipe, flashed with Cobb's Stage 2 93 with no issues. On my car, it's most noticeable at low boost, the rest of the exhaust sounds drown it out above that.
gjhsu is offline   Reply With Quote
Old 11-08-2005, 09:20 AM   #7
Alan l.
Member#: 90085
Old 11-08-2005, 10:21 AM   #8
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
from my understanding:
too tight = boost spike
too losse = flutter
joe
scoobdude is offline   Reply With Quote
Old 11-08-2005, 11:37 AM   #9
Alan l.
Member#: 90085
too losse = flutter
joe
That was my understanding too
Old 11-08-2005, 07:07 PM   #10
Alan l.
Member#: 90085
Old 11-09-2005, 01:11 AM   #11
RobSub
Member#: 88205
2005 Legacy 2.5GT
I dont think there is a solution to the flutter. from what I have heard, wrapping the downpipe will minimize the sound travel.
RobSub is offline   Reply With Quote
Old 11-09-2005, 02:09 AM   #12
hlanderr
Member#: 85869
The Blue Sube
wasnt there a post a while ago with a quick fix to the wastegate arm in this common upgrade with UP/DP with cobb?
it was something regarding tightening the wastegate a few times or something... not sure
hlanderr is offline   Reply With Quote
Old 11-09-2005, 02:16 AM   #13
MBasile
Member#: 86997
2002 Impreza WRX
I thought wastegate flutter sounded like air seeping (sp?) out and kinda fluttering? thats what my car does when it starts to boost and my friend said it might be slight wastegate flutter but he didnt know how to fix it.
MBasile is offline   Reply With Quote
Old 11-09-2005, 09:21 AM   #14
Alan l.
Member#: 90085
I did the WG adjustment and the car ran fine with stage 2 for atleast 2K miles. One thing strange is that the noise i'm hearing only comes on when I go light on the throttle from a standstill start then decide to floor it 2 seconds later (no downshifting, still in 1st gear). If i floor it from the start, no noise. If i floor it while i'm moving on the highway and the car downshifts (4eat), no noise. Only happens when i'm light on the throttle then hard. I hear some pulsating noise that happens for a few secs and then goes away as the rpms gets closer to redline.
My mods include
05 92x AT w. 4300 miles
Accessport 93 octane stage 2 base map
Crucial racing up pipe
Crucial racing down pipe
Samco IC hoses
GP moto intake hose (MAF hose)
Stock air box w. silencer removed
Greddy SP2 cat back
Wastegate arm 3 turns tighter
cobb stage 2 vs. prodrive stage 2 oxtox Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-22-2005 08:59 AM
Cobb stage 2 (w mods) VS. Cobb stage 2 (w mods) Happy_Days Proven Power Bragging 7 11-28-2004 04:25 AM
Cobb Stage 2 and Wastegate Adjustment Fingerbang Engine Management & Tuning 4 10-12-2004 01:50 PM
Turbo XS Stage 2 or Cobb Stage 2???? NBWRX04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-24-2004 07:32 PM
TXS stage 2 Unichip vs Cobb Stage 2 Access ECU ezatnova Engine Management & Tuning 8 02-09-2004 08:54 AM
