Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 11-07-2005, 12:30 PM   #1
LoveRoadRacing
Member#: 80500
2002 2.5L WRX
Blaze Yellow
Default WRX Track Alignment
Looking for feedback on what others have had success with on the track with hi-performance suspension. I seen posts saying anywhere from -1.5 to -2.6 front, -1.1 to -1.4 rear and zero toe front and rear.
I've run victo racers and Potenza RE70's and experience understeer with both. Other rex's have noted the same issue of troubles turning in. I'm inclined to think that with the stiffness I have that -2.6 in front may be excessive up front and that a smidge toe out in the rear would be justified.
Thoughts????
LoveRoadRacing is offline   Reply With Quote
Old 11-07-2005, 01:48 PM   #2
ChrisF
Member#: 12295
What sway bars are you running and at what settings? That would make a huge difference as far as pushing goes.
On my STi, my daily/track setup is
Front:
-2.5 camber
6 deg caster
0 goe
25mm Hotchkis bar/links
Rear:
-1.8 to -2 camber
1/32nd toe IN
25mm Hotchkis bar/links on middle hole
Car feels fairly neutral with mild slow power on oversteer out of 1-2 gear corners. Mind you, I have the benefit of more torque and STi diffs so YMMV. I've run this setup on both street and R compounds.
ChrisF is offline   Reply With Quote
Old 11-07-2005, 02:07 PM   #3
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Chris: And judging from your tire wear, you could still use a bit more negative camber up front on those track days.
Arnie is offline   Reply With Quote
Old 11-07-2005, 02:11 PM   #4
ChrisF
Member#: 12295
Amen to that Arnie. I'm thinking -3 to -3.5 if I could get the plates to go that far.
Old 11-07-2005, 04:13 PM   #5
LoveRoadRacing
Member#: 80500
2002 2.5L WRX
Blaze Yellow
Thanks for the reply Chris
Of course it would be rear toe-in.... I've got whiteline rear bar on middle hole with Perrin end links, it appears the front is stock. Zeal V6 coil overs set on 5. Cusco strut and triangulation braces. Torque and HP not an issue .
What caster/camber device do you use? I'm looking at the Longacre.
Old 11-07-2005, 04:15 PM   #6
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Chris is using PDE plates, caster and camber adjustable.
Old 11-07-2005, 04:18 PM   #7
ChrisF
Member#: 12295
Arnie is correct. I'm using PDE front plates in conjuction with camber bolts and regular bolts in the rear. Didn't your V6's come with plates fr/rr?
There's another big variable to play with: damping on the V6's. My research on the web as well as my personal experience with the V6's was that they liked a 2 pt spread in damping. But if you're looking for more rear rotation...little more in the rear wouldn't hurt. What kg springs are you on?
Loved the Zeals; just couldn't live with them every day.
Old 11-07-2005, 04:41 PM   #8
LoveRoadRacing
Member#: 80500
2002 2.5L WRX
Blaze Yellow
Thanks for the input guys. Yes there are camber plates there, but I'm somewhat in the dark as I purchased the car with Zeals installed, no instructions and haven't been able to locate. Don't have spring info either, all I can tell you is they're blue. I should have clarified as well that I assumed you are doing your own adjustments and inquiring as to the tools/equipment you're using (Arnie included!)
street and track alignment? elirentz Brakes, Steering & Suspension 8 10-11-2006 03:22 PM
Quick Track alignment question.... TubeDriver Brakes, Steering & Suspension 3 07-26-2005 02:12 PM
autox alignment vs track alignment BIGSKYWRX Brakes, Steering & Suspension 2 06-23-2002 07:27 PM
Track Alignment? Ru fan Motorsports 4 06-22-2002 10:08 PM
WRX Stock alignment adjustable? marka123 Brakes, Steering & Suspension 4 02-16-2001 10:33 AM
