Old 11-08-2005, 10:22 AM   #1
Lancer3d
Member#: 59103
2003 WRX
GunMetal
Default USDM STi injectors in USDM WRX
I was just wondering if I put USDM STI fuel rails and injectors into a 03 USDM WRX, will they work? I got some information that it is the fuel rails that decide if the engine uses top feed or side feed. Can someone please brighten me on this please?
Thanks
Lancer3d is offline   Reply With Quote
Old 11-08-2005, 05:08 PM   #2
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
no they wont work, the mounting points for the fuel rails are different you would have to swap over the engire intake manifold/fuel rails to get it to work.
jnorth85 is offline   Reply With Quote
Old 11-08-2005, 05:19 PM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
are the new WRX injectors and rails the same as the STi?...I'm assuming yes
Old 11-08-2005, 05:23 PM   #4
Lancer3d
Member#: 59103
2003 WRX
GunMetal
no they are still different, wrx is still top feed, and sti is still side feed. I asked the question because I heard that side feed is better, and I can get USDM STI rails and injectors cheaper than JDM pink injectors
usdm STi injector in EJ20R TRBO_BXR Pre-2002 Factory Turbo Powertrain 2 04-21-2010 03:44 PM
04 USDM STi cluster in 04 WRX AWDrifter21 Electrical & Lighting 19 05-03-2006 11:02 PM
How to wire a USDM STI DCCD in 02' WRX??? ejsportcom Subaru Conversions 8 09-16-2005 08:50 AM
USDM Sti Injectors in 98rs NeaD Normally Aspirated with bolt-on Forced Induction Powertrain 4 06-07-2004 05:54 PM
04 USDM STI cluster in 03 WRX? Equilibrium Tuning Interior & Exterior Modification 4 06-22-2003 08:34 AM
